Mobi Washers - shou...
[Closed] Mobi Washers - should the motor cut out when you release the trigger or
[#3215798]
.. should the motor continue running and sound like it's struggling when the water isnt flowing?
I got a new V15 (the psa wiggle £50 one) one last week and it's not behaving like the car (mains powered) ones I've tried that always cut out.
Apologies if I'm being a numptie.
Posted : 05/10/2011 9:01 pm
When you release the trigger and shut off the water jet the motor should cut out, unless you are out of water.
Posted : 05/10/2011 9:06 pm
Thanks old_mtber.
I'm off to google the wiggle warranty procedure.
Posted : 05/10/2011 9:20 pm
Check all the connections on the hoses and lance are fitted properly. It'll keep pumping if it's losing any pressure at all.
Posted : 05/10/2011 9:23 pm
make sure the engine is running or you will get this happening
Posted : 05/10/2011 9:27 pm
I've checked and double checked this. There is no water leaking anywhere - or any hissing noises.
I tried that too - the pump / spray is more powerful for sure with the engine running but it still doesnt cut out. I also tried another car.
Thanks for the replies!
Posted : 05/10/2011 9:31 pm
mine does it when engine is switched off but does cut out if running.
Posted : 05/10/2011 9:32 pm
