Mixing rotors with ...
[Closed] Mixing rotors with brakes
[#3296998]
Evening!
Got a set of Avid Elixir R brakes - 185/160 and I'm thinking I'd prefer my hope M4's on there...the Hopes are 183/160 and I was wondering how much of an issue the extra 2mm of rotor will be? Also is the braking surface the same size?
Clearly I've not had a chance to get to the garage to compare the braking surfaces on either rotor to answer this but I'm more thinking of the potential issue of the front brake being a 183 on the Hope and a 185 on the Avid.
Avid's seem to stop me fine but they feel awful...very 'squidgy' but all Avid's I've tried feel like that and I don't like it...
Posted : 30/10/2011 9:24 pm
Not ideal, but you could put the M4's on with a couple extra washers to accommodate the extra disc size.
Personally I don't like to many washers on a brake mount, so I'd just sell the complete set of Avid's you have and then buy some new rotors to suit the Hope's.
Posted : 30/10/2011 9:29 pm
I'd suggest trying a good bleed, making sure the pistons are moving freely, and the calipers are correctly aligned (not pull the lever then tighten the bolts). I do this day in-day out with Avids, spend the time to set them up correctly, and you'll have a rock solid lever with minimal travel.BTW, I hate them for the time they take up, but they do work very well if you spend the time.
Posted : 30/10/2011 11:10 pm
The rotor has 2mm extra diameter but only 1mm extra radius - not worth bothering about! I use Hayes rotors with my Juicys and I never have any problem.
Posted : 31/10/2011 12:07 am
