Minion 2.5"
[Closed] Minion 2.5"
[#10211404]
Would a Maxxis Minion 2.5 be ok on a 25mm internal rim?
Posted : 06/09/2018 10:37 pm
Was running them on Flow EX 25.5mm rims for years with no issues.
Posted : 06/09/2018 10:39 pm
You mean current WT 2.5? No. Needs 29mm and up really.
Mike probably means the old 2.5, which I ran fine on 24mm internal.
Posted : 06/09/2018 10:44 pm
Running the WT's currently on my ST I25's again still going well (internal 25mm)
Posted : 06/09/2018 10:48 pm
I think if you didn't know it was a WT, you wouldn't care.
Posted : 06/09/2018 10:52 pm
Running my DHF 2.5" WT on AR27 (27mm internal) rims, no issues at all.
[url= https://farm1.staticflickr.com/948/41848929712_7ed1a97b77_b.jp g" target="_blank">https://farm1.staticflickr.com/948/41848929712_7ed1a97b77_b.jp g"/> [/img][/url][url= https://flic.kr/p/26L3GNU ]IMG_20180504_195923[/url] by [url= https://www.flickr.com/photos/tallpaul_s/ ]Paul Sims[/url], on Flickr
Posted : 06/09/2018 10:53 pm
 cnud
Er, I’ve run a 2.5WT all summer on a Mavic XL which is 23mm internal but I only tend to ride the Peak. I guess it may be a different story if I was railing berms to the max at a trail centre.
Posted : 06/09/2018 10:54 pm
If you don't care where the side knobs kick in, you can mount any tire on any width rim. I have a 2.5 WT on a 29mm, and a 2.4 WT on a 27mm… both good. Any narrower and you'd have a pretty vague patch when leaning… especially if you ended up running higher pressures to stop squirm.
Posted : 06/09/2018 11:22 pm
Any narrower and you’d have a pretty vague patch when leaning… especially if you ended up running higher pressures to stop squirm.
Really, what you run it on? Going well here, nice and grippy too along with good old minion predictable
Posted : 06/09/2018 11:31 pm
What rim tyre combinations have you tried Kelvin?
Posted : 06/09/2018 11:38 pm
I’ve got a dhf 2.5 wt which I’ve been running on a DT Swiss e1900 650b wheelset which are 25mm internal diameter. Seemed ok to me - certainly better than the 2.3 dhr2 that I was running on there before - both in grip and predictability. Same compound rubber.
Posted : 06/09/2018 11:45 pm
Cheers guys
Posted : 07/09/2018 5:59 pm
There are more than a few DH bikes being raced on ex471 25id rims this weekend at world championships.
Posted : 07/09/2018 10:09 pm
In a blind taste test I doubt you'd notice.
Posted : 07/09/2018 10:11 pm
DHF 2.5 WT works really well on a Flow EX (25.5mm internal). As do the DHR2 2.4 WT and Shorty 2.5 WT.
Running about 24psi at 13 stone odd. And I hate squirm.
Posted : 08/09/2018 10:09 am
Running one up front on a Ryde 26mm ID rim.
To be honest it's no bigger than the Bonty Xr4 2.35 it replaced.
Posted : 08/09/2018 7:09 pm
