minimum insertion,o...
[Closed] minimum insertion,oo er missus!
[#7675362]
Well my dream frame arrived.
A Kinesis Sync.
Strictly on trial mind for size.
Top tube dimensions and headtube were fine.
Teeny 19.5 seat tube maybe not.
Got a 400mm post but barely two or three Inches past the top tube intersection.
Probably be ok but still a little disconcerting the amount of the post hanging out of the frame!
Am I being a picky git?
After much consideration it has gone back and back to the drawing board!
How much would you consider safe in the frame?
Other than that maybe a Stanton Sherpa ti or something custom by Brant?
Thanks,
Max
Posted : 27/02/2016 7:34 pm
You'll be fine.
[img] ?w=480&h=480&fit=clip[/img]
[url= http://rs239.pbsrc.com/albums/ff167/LukeBurstow/071_zpse96421f8.jp g" target="_blank">http://rs239.pbsrc.com/albums/ff167/LukeBurstow/071_zpse96421f8.jp g"/> ?w=480&h=480&fit=clip[/url]
Posted : 27/02/2016 7:48 pm
Fit a dropper maybe?
Posted : 27/02/2016 8:44 pm
Thanks wwaswas!?
I will be fitting a dropper but also a normal post for xc racing.
May look toward a 21" frame.
Stanton looks good but a large head tube.
Posted : 27/02/2016 9:09 pm
Even on a 19" frame (@6'2") I was having to run flat bars and a negative 10degree stem to get the bars low enough for xc racing....looks quick though.
Posted : 27/02/2016 9:24 pm
Yes,same height and also flipped stem and flat bars.
Currently riding an XL Giant XTC 29 with a 120mm headtube.
Don't want to go higher.
Stanton in XL is 140mm.
Seat tubes seem to be an issue with us taller folk!
Thanks,
Max
Posted : 27/02/2016 10:26 pm
