Middleburn Rings on...
[Closed] Middleburn Rings on XTR 970 Chainset?
Anybody fitted any middleburn rings to either xt or xtr cranks. I thought i'd read somewhere about having to shim outer ring but could have imagined it. How do you lot find the rings shifting and durability.
Posted : 13/03/2012 10:27 am
On M970s you need some 2mm spacers on the inner ring. I ran TA rings on mine (with spacers) and they were fine.
Never been a fan of Middleburn myself, don't find they shift all that well. Admittedly not used any for a long time though.
Posted : 13/03/2012 10:29 am
on a side note njee20 do std chainring bolts fit? I converted mine to single ring and now i've misplaced the originals, i think i still have the inner ones though
Posted : 13/03/2012 10:31 am
I've run Middleburn chainrings on XT M770 Cranks no problem, only small and middle rings though as I use a bash.
Posted : 13/03/2012 10:40 am
Yep, they're just normal M8 bolts.
Posted : 13/03/2012 11:01 am
Think middleburn make a ring just for hose chainsets to avoid needing the spacer but
It cost more than a normal one
Posted : 13/03/2012 11:14 am
use with 2 ring and bash and workls well not as good shifting as prope XTR rings but not enough to worry about
Posted : 13/03/2012 11:27 am
So you Junkyard you reckon its worth trying them....cheapest i've found for a set of xtr is £198.00...few years ago i would have paid it but crc are doing full chainset for under £300!!!!Might buy one and put the other on here.
Posted : 13/03/2012 12:24 pm
