Middleburn Cable Oi...
[Closed] Middleburn Cable Oilers - how many do you use?
I'm thinking one on a full length front mech and maybe 2 on a full length rear, or is one on each cable enough? Positioned half way along?
And what's a good lube to use?
cheers
Posted : 29/11/2012 9:44 am
1 on each cable, I put it in the middle of the bend the cable takes from the shifter as I rekoned this to be the highest point of drag in the system... I have a shaddow type rear mech so cable routing is quite straight, if I didnt I would have possibly added another in the middle of that bend as well.
Posted : 29/11/2012 10:11 am
I use 2 on my rear cable. 1 on front.
1/2 way on front and 1 by headtube + 1 by chainstay for rear.
GT85 is fine.
You do however still need to change the inner every couple of years though - I've had one snap on me, presummbably from fatigue/old age.
Posted : 29/11/2012 10:14 am
I run one per cable section. my thinking is 1/3 of the way down so to compensate for gravity. I also put them on straight section rather than on the bend so they don't add to drag and the housing end will sit more fully located. I use gt85 but find I get a lot of back spray from it.
I'd use two on a full length front and three on a full length rear I think, then "chase and first, down the cable.
Posted : 29/11/2012 10:23 am
Thanks for the tips. I've just realised that they come in packs of 3, so 2 packs should do 2 bikes.
Posted : 29/11/2012 12:10 pm
