middleburn cable oi...
[Closed] middleburn cable oilers ?
[#4606248]
anyone used these?
i was thinking about sticking them on my full outer set up...
opinions gladly received...
paul
Posted : 29/11/2012 12:41 pm
I have some but never really use them
Not sure how many I have but some red and some gold ones
E-mail in profile if you want them [FREE]
Posted : 29/11/2012 12:47 pm
They do what they say they do. Weather they are really necessary is anyone's guess, but they seem to make a difference to me 🙂
Posted : 29/11/2012 12:51 pm
Got them on my full length XT outers as newer Gore cables I had on couple of winters ago didn't even last 6 months and had been fitted properly.
They seem fine so far, making it through one winter, got 3 on the whole length and just a squirt of lube once a week or so during the winter and probably once every 2-3 weeks the rest of the time.
Posted : 29/11/2012 1:30 pm
If you have full outers, I wouldn't bother if you have decent semi-sealed end caps. They certainly prolong the life of cables when you are running a few sections of outer and water/crud can get in at a few points.
Posted : 29/11/2012 1:40 pm
I run them on my commuter and they definitely help keep things running nicely.
For the money I'd say they are worth it.
Posted : 29/11/2012 1:42 pm
I've got them and they work. They cost £6 and make it a 1 minute job to look after your cables and keep them working smoothly in filthy sub zero conditions. No brainer IMO
Posted : 29/11/2012 1:51 pm
I think that they are a great, inexpensive, worth while addition to most bikes.
I had them on both my Alfine set ups (8 and 11),it makes a difference because its a little bit of a pain to lube cable outers on a Alfine (re-setting up the gears each time).
Now i'm back running a 'normal' cassette with internaly routed cables i'll add them in when i next need to replace the cables.
Posted : 29/11/2012 2:03 pm
I've got some on my ST4 fitted with a Rohloff and I think they are great.
Definately recommended!
DAVE
Posted : 29/11/2012 2:07 pm
I've used them now for a few years on all bikes I put together - they are excellent.
I usually install one about 75mm from each shifter, & one on the rear mech outer on the chainstay/seat stay.
Quick blast with GT85 every few washes.
Posted : 29/11/2012 2:20 pm
 FOG
not a massive game changer but definitely do seem to keep cables smoother longer. If you are changing cables and outers anyway the small extra expense is worth it.
Posted : 29/11/2012 3:18 pm
