Met Parachute, hone...
[Closed] Met Parachute, honest opinion please
2 unfit - Yes - much better - its the EPS that actually is the bit that works - It absorbs some of the energy as it crushes and also makes the acceleration occur over both a longer time and distance. Have a look at my link on the other page for a simple explanation of how cycle helmets work
Posted : 28/02/2011 9:30 pm
I give up. Apparently my face has hit the ground so many times without me realising that i now know why I'm so goddamm handsome!
Posted : 28/02/2011 9:31 pm
Your point.
Posted : 28/02/2011 9:32 pm
What in particular are you unable to understand al -
Posted : 28/02/2011 9:33 pm
To the OP after reading this anyone that has a met and has used it (crashed ) has seemed more than pleased with it. I have one but have not tested it (thankfully). These people that have experience of this have much more relevance in this thread than the naysayers who have no proper experience of this.
Posted : 28/02/2011 9:38 pm
You are saying a chin guard has a negative effect unless it has EPS, yes?
But you previously said Coulthard's helmet was effective and other full facers not, because it's chin-guard is close to the face, yes?
Those appear to contradict one another (as I've made clear already on this thread, and you've ignored, so don't patronise me, sonny).
Further, You'v also said that a helmet will spin round until the chin-guard hits your face. I just don't see how that can happen if it remains strapped to your head.
*waits*
Posted : 28/02/2011 9:39 pm
I had one, crashed badly on rocks, still have face intact. Have no doubt at all would have been a serious level of damage to my face without it. Only replaced with proper full face as my riding got more and more gravity based.
LOL at TJ, he knows better than all this real world experience, what a tool.
Posted : 28/02/2011 9:48 pm
No - again thats not what I said Coulthards helmet is an interesting design that attempts to answer some of the criticisms of conventional helmets
Its your lack of understanding both of the basics of how helmets work and you lack of understanding of my point that leads you to be confused. How can I explain something I have not said?
You don't see you it can happen 🙄 Just try it by hand - you will be amazed how far a helmet even with eh straps done up properly can move on your head.
Try this with your XC helmet. put it on as normal. bend your neck forward and grab the back of the helmet and try to rotate it off forwards - see how far it moves
So yes - I was absolute;y correct eh first time - its an utter waste of my time to try to expalin anything to you
Read the link I gave you on how helmets work.
Posted : 28/02/2011 9:50 pm
I understand that the EPS absorbs impact.
But say you wanted to punch a brick wall (example only), if you held a cheap simple square (EDIT, or preferably D shaped) of fairly flexible plastic in your fist an inch or two away from your knuckles so that it hit the wall before your knuckles, would that deflect more of the impact that say 3mm or so of EPS?
Posted : 28/02/2011 9:52 pm
pack it in you two tarts. 🙄
Really i do wonder what the hell i see in you both..
Posted : 28/02/2011 9:56 pm
I, like other people on this thread, have crashed wearing a Parachute. Like them the chin guard did not smash into my face nor did the helmet rotate unil the chin guard hit my face.
As Richard Feynman said
“It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong”
Posted : 28/02/2011 10:19 pm
Jezza
legend the helmet will rotate around your head until the chinbar hits your face given a seizable impact.
You head will be moving away from the rest of the helmet so it offersno support
That is utter Pish
Giro, Met, Specialized and many others have been building full facers and the switchblade type for many years.. the head is locked into the upper helmet.by retention systems.
it all works as a package.. the chin guard is designed to deflect mainly and partly transfer force into the main helmet.
Posted : 28/02/2011 10:21 pm
soulrider - try doing the rotation test I suggest - I bet you will be very surprised how far the helmet can rotate. Go on = please try it and report back.
Posted : 28/02/2011 10:25 pm
Better than using gravel to rotate your face. Which is the alternative.
I suppose gloves are pointless too? Mine certainly don't have 2" of padding on the palms. I'd rather crash in shorts than naked too, even though they're utterly worthless at reducing impact and undoubtedly untested.
Don't let the obvious stand in the way of a good lecture though. Please carry on.
Posted : 28/02/2011 10:30 pm
Oh well, what a palaver. I bought it to protect my bonce like a open face would do, plus some extra protection on top of that.
Anyway-
Will the Met Parachute do more harm than good?
Posted : 28/02/2011 10:44 pm
*cracks knuckles*
TandemJeremy - Member
You implied it by saying as below - even if you didn't my point still stands on what you said.
The chinbar is not tested as a part of standards testing and contains no EPS so will do little to take the energy out of impacts
Fair enough - see how I AM UNDERSTANDING WHAT YOU ARE EXPLAINING ❓
You have yet to demonstrate that I do not understand how helmets work (I certainly don't know how you work).
You don't see you it can happen Just try it by hand - you will be amazed how far a helmet even with eh straps done up properly can move on your head.
Just did. No it won't, it will hit your neck.
No you weren't 🙄
Seriously, if you have such a low opinion of me or contempt for me, why even engage me, if it upsets you so much ❓
Posted : 28/02/2011 10:54 pm
You two are engaged now?
Should I buy a hat?
Posted : 28/02/2011 10:55 pm
*hums "the circle of life"...*
Posted : 28/02/2011 10:59 pm
Should I buy a hat?
Only if it has a chinguard.
Tinfoil one might be best druidh
Posted : 28/02/2011 11:00 pm
Is it bed time already?
Posted : 28/02/2011 11:02 pm
Given up eh? 🙄
Mummy's calling me to bed now.
Posted : 28/02/2011 11:05 pm
cynic al - I know from attempting to explain to you on this thread and on many others that it is a fruitless task.
I have given you an explanantion on this thread but you reject it completely without any reasoning or understanding.
You will NEVER accept any explanation I give, you will attempt to find fault in anything I say, its an utter waste of my time and effort discussing anything with you.
Proven I believe
Posted : 28/02/2011 11:06 pm
Yes that's right, ignore all of what I post and claim I'm not listening.
Hypocrite.
Posted : 28/02/2011 11:08 pm
More personal insults. You really are a very bitter and nasty man.
There is nothing to answer - you claim I say things I do not, you claim that me saying "contains no EPS so will do little to take the energy out of impacts" actually means "has a negative effect unless it has EPS, "
Posted : 28/02/2011 11:12 pm
Enough of the foreplay you guys and just get jiggy, you know you love each other really.
Posted : 28/02/2011 11:13 pm
 nonk
the pair of you need a slap.
Posted : 28/02/2011 11:15 pm
edited
WTF do you expect when you respond like you have? Can you see how you come across?
Not at all, I barely GAS About this crap, only just enough to give myself a laugh on a Monday night. Would quite happily have a laugh with you over a pint about it all if you were up for that.
Please don't mis-quote me for your own ends...I said
You implied it .... even if you didn't my point still stands on what you said.
Posted : 28/02/2011 11:25 pm
with a helmet strapped correctly and the retention system tight there is damn near no movement
even swinging on it..
Posted : 28/02/2011 11:35 pm
Do you think there's any way out of this thread that won't leave both of these guys looking like raving lunatics?
Posted : 28/02/2011 11:40 pm
Ah **** do I look like a loon already?
Posted : 28/02/2011 11:42 pm
You're expecting them to come out of it looking better than when they went in? 😯
Posted : 28/02/2011 11:43 pm
There just sorting through a few issues, normal service will resume in a day or two, been great reading.
Thanks lipseal, I'm glad my works finds an audience - but this [i]is[/i] normal service 😡
aracer, I assume I'm always starting at rock bottom, only way I can go is up.
Posted : 28/02/2011 11:47 pm
did you two go for a pint then?
Posted : 01/03/2011 9:11 am
He appears to have declined my invitation.
Posted : 01/03/2011 9:16 am
Wow, this is still kicking off 8)
Soooo, does anyone actually [i]know[/i] anything about PPE for biking or are most of these :facts: just 'something I read somewhere'
I can't actually work out what the TJ roatation test is as the description is quite loose...
...but my simple old Specialized XC lid has almost zero movement in any plane when the straps and retention system are correctly fastened so I join the people who do not agree that a chinguard (on a correctl fitted and fastened helmet) will rotate sufficiently to hit your face.
Posted : 01/03/2011 9:32 am
I can't understand the argument that without EPS there is no protection. If this is correct then every helmet worn on every building site around the world is not providing any protection, however I would much rather a brick fell on my head wearing a hard hat than without.
Posted : 01/03/2011 10:29 am
but have you rotation tested your hardhat bigjim?
No?
Idiot. 🙄
Posted : 01/03/2011 10:31 am
That's because it's not an argument (objective, interactive discussion of established data) but a viewpoint(subjective, monologue exposition of third party opinion)
The only thing to remember is 'it's your head, protect it how you wish'
I'm fortunate enough to never have had a potentially life threatening head impact but my helmet has saved me from innumerous medium level injuries, mainly of the '****ted in the face by an overhanging branch' variety and made several tumbles a 'dust yourself down' job rather than a 'ooooh that looks nasty' incident
Posted : 01/03/2011 10:40 am
No?
Idiot.
😆 No but I have 'tested' three helmets without face protection and been very glad of their presence. Been lucky not to land on my beautiful face yet.
I've had one bad one and it wasn't much fun - I recommend sticking to the low flying bracnhes!
Posted : 01/03/2011 10:46 am
Hilldodger - the point is - and it is a fact - that the eps is the main mechanism that reduces the effects of hard impacts. At no point did I say it offers [b]no[/b] protection without the EPS - what I actually said was
contains no EPS so will do little to take the energy out of impacts.
This is why construction type helmets are not used. This is why a chinbar with no eps is limited in how well it will work as without the EPS the largest component of impact protection is absent.
How do helmets work?
Helmets are normally comprised of four elements; a rigid outer shell, a crushable liner, chin straps or a retaining system and fit or comfort padding. The rigid outer shell when present adds a load-spreading capability, and prevents objects from penetrating the helmet. It's kind of like an additional skull. [b]The liner[/b], usually made of EPS (expanded polystyrene) or similar types of materials [b]absorbs the energy of an impact by crushing[/b]. The chin strap when properly buckled and adjusted along with the fit padding helps the helmet remain in position during a crash.
Helmets work kind of like a brake or shock absorber. During a fall or crash a head is traveling at a certain speed. Since the head has weight, and is moving there is a certain amount of energy associated with the moving head. When the helmet along with the accompanying head impact an unyielding object; a rock, a wall, a curb or the ground the hard shell starts by taking the energy generated by the falling helmet (head) and spreads it over a larger portion of the helmet, specifically the internal foam liner. [b]The foam liner then starts to crush and break which uses up a lot of the energy[/b], keeping it from reaching the head inside. Depending on how fast the head is traveling, and how big, heavy and immovable the object is the faster the head slows down, and the more energy is present. In short everything slows down really quickly. A helmet will effectively reduce the speed of the head by breaking and crushing which reduces the amount of energy transferred to the brain. The whole process take only milliseconds to turn a potentially lethal blow into a survivable one.
Snell foundation
http://www.smf.org/faqs.html#9
Posted : 01/03/2011 10:49 am
So by the same argument you are saying construction helmets do little to take the energy out of impacts?
Posted : 01/03/2011 10:55 am
Yes. They spread it around and the flexing will take some - but construction type helmets are designed for impacts are much lower energy that bicycle ones
Helmets designed for lesser impacts do not necessarily have foam inside. Some are just hard shells with a suspension headband that provides the fit and keeps some space inside for air to circulate. Construction helmets are of this type, and do a fine job when somebody drops a brick on your head or you bump hard against an overhanging steel beam. Just don't fall off a bicycle with one, since they will not handle the impact of falling on pavement.
http://www.bhsi.org/general.htm
Posted : 01/03/2011 11:00 am
Tj nothing in that excerpt discusses chin-guards.
energy absorption must be different in chin-guards.
+ the numerous points I made above that you are choosing to ignore.
Posted : 01/03/2011 11:08 am
 DT78
Well I don't know much about the pointless bickering that is going on but I own a parachute and three other of my mates also bought one after having to take a rider buddy to A&E when his front wheel slipped off the boardwalk on one of the afan trails (wall or whites I forget which)
As he went down the side of his face scraped along the chicken wire put on it for grip and he is now scarred for life.
As far as I'm concerned it is a wise investment if you value your good looks and occassionally come off the bike. I'm surprised more manufacturers don't produce them.
You do feel like a tool wearing it though.
Posted : 01/03/2011 11:16 am
Yes, well done thats what I wanted you to pick up on - the hard material transfers most of the energy, and absorbs some, so what the face part of the Parachute does is transfer the energy from the chin into the rest of the helmet to be distributed and absorbed.
Posted : 01/03/2011 11:21 am
Aye bigjim - the energy has to go somewhere. Yes the parachute will be effective against small impacts. However the energy has to go somewhere - and a faceplant in a parachute with a high impact speed that energy will still go into the head somewhere as there is no eps getting crushed to actually absoeb the energy. The flexing of the hard shell will not absorb forces of the magnitude involved when you hit a tree flat out. Thats when you need the eps
Posted : 01/03/2011 11:26 am
Its difficult to see who's showing themselves up worst here, Al or TJ.
2 grown men battling out some pointless debate on the internet.....
Posted : 01/03/2011 11:36 am
 goog
oh dear 😐
Posted : 01/03/2011 11:52 am
I don't think you can state anything about that without knowing how the chin guard part is mounted on the helmet - it might be quite well engineered so that the energy is transferred into the EPS and/or through the inner nylon cage effectively. My mate has one so I'll have a look at the weekend.
But anyway it is clear the helmet will provide face protection which is why people are buying them, and based on the users in this thread they do work.
Posted : 01/03/2011 11:59 am
Surely, a chin guard is not designed to work the same way as the rest of the helmet, otherwise it would be like a close fitting beard type thing of the shape that industrial designers called Oswald would sport? Which would clearly be ridiculous.
As I see it, the main inner shell of the helmet crushes when pressed betwixt your head and a hard surface (tree trunk/rock/frying pan) and the energy absorbed in crushing the polystyrene is what saves your noggin' from splitting open like a coconut.
The chin guard is designed not to deform, but to create a crash barrier between your face & the ground. Sure it'll deform a bit, but that is a by product of the impact.
The chin guard keeps your delicate Nivea soaked face away from the jagged hard bits that want to rip it to shreds. What happens to the energy is of secondary importance, as far as the chin guard is concerned - presumably the impact shunts the helmet & your head backwards/sidewards until the rest of you catches up/stops. Even if the helmet decides it wasn't put on properly & the chin guard hits your face as a result of the whole lot moving, then at least you are left with an interface which consists of face/plastic chinguard/rough, scrapy stuff, compared with face/rough, scratchy stuff.
A mate of mine has one and it saved his features quite well at Penmachno once when he sailed over the bars at speed. There was quite a lot of chin guard scrape-age, but his features remained intact. He is unwilling to repeat the crash with a normal helmet to compare the results, which quite frankly is a bit selfish, if you ask me.
Posted : 01/03/2011 12:25 pm
Deal with it people, everyone is wrong other than TJ (of no ff helmet experience)!
Posted : 01/03/2011 12:30 pm
I just don't see what TJ is trying to say, but he's ignoring me now anyway.
stumpy has put it well, I've lost the will for now.
Posted : 01/03/2011 12:38 pm
I have a full face Casco Viper. I've slammed down a couple of times on to rocky surfaces.
Due to the helmet being there I had no injuries to my head or face.
This is fact, based on experience.
My head did not twist off, knock round, spin or otherwise whiplash.
Again fact.
Transfer of energy, my arse, I'd rather the chin guard hit the ground than my teeth.
Posted : 01/03/2011 12:50 pm
That's the thing that 'gets me' about some peoples stance......
......someone posts based on their own direct experience but that's dismissed as 'anecdotal evidence, not peer reviewed' but something C'n'P from a website of unknown relevance or accuracy is :FACT:
So in the absence contributions by any experts on bike helmets &/or head injuries, let's leave the Google search button alone and agree that it's all down to personal choice
Posted : 01/03/2011 1:02 pm
i loikes the way that when everyone on here does the TJrotational test, they do up the straps and adjust the retention device
nobody actually rides with their lid on properly in real life
Posted : 01/03/2011 1:42 pm
I'm not reading all of this rant, but I got a Parachute as it covered more of the back of my head than anything else I could find.
but i don't really like the full-face bit, so am thinking of replacing it with Fox Flux/661 Recon etc.
Posted : 01/03/2011 1:45 pm
Oh, the back of your head, I should perhaps wear my kneepads on the backs of my knees. Do you ride backwards? 😀
Posted : 01/03/2011 1:51 pm
Whats the Casco Viper like? its cheaper than the MET one. This thread has made me want a full face 😆
Posted : 01/03/2011 1:56 pm
Nice and light, well vented, looks big and numb, but I've never come across one that doesn't.
You're glad of the coverage when you're going through rocky sections clipped in.
Posted : 01/03/2011 2:03 pm
not on purpose I don't. but helmets are generaly used for those "not on purpose" moments.
I've got a big head. Most helmets perch on top like a frikkin' skull-cap.
Posted : 01/03/2011 2:15 pm
If you need a full face helmet buy one, if you need a regular cycling helmet buy one of those. The Parachute is neither. The biggest danger is the uncertified removable chin guard breaking. It's weak points are uncomfortably close to important blood vessels IMHO.
Posted : 01/03/2011 2:47 pm
Interesting. If I was going to buy one (which I'm not at that price) I would go with those who have said it works based on experiences they and their mates have had and not on some ludicrous manual twisting test.
Having said that, with just one deflection away from the face it could pay for itself several times over in dental costs, not to mention jeopardising my modelling career.
*ponders*
Posted : 01/03/2011 5:49 pm
I remember that incident, it was messy. On Goodwood, White's Level, Glyncorrwg. How's your mate doing nowadays?
Posted : 01/03/2011 6:21 pm
 DT78
Really? T'was a few years ago now alot of people were about so you may have been one of the helpers...apologies if I don't remember your name
I have not been with a ride with him since - to my knowledge he has never been properly offroad since, it finished mountain biking for him. A really scary moment was when his tongue swelled up and he started to choke...
3 of us bought parachutes pretty much immediately after that. To be fair I no longer wear mine as much, but something like that puts things in perspective.
Hey ho, lets have a pointless bicker about whether it may or may not hypothetically work...
Posted : 01/03/2011 6:46 pm
I wasn't there but a mate was, and having Whites as a local ride I had an interest and was pretty shocked to see the pics that were put up.
I agree, epf may well absorb shock, but if your friend had been wearing a Parachute his face would not have been damaged in the way it was. I hope he's doing well.
Posted : 03/03/2011 11:28 pm
Page 2 / 2
