pack it in you two tarts. 🙄
Really i do wonder what the hell i see in you both..
I, like other people on this thread, have crashed wearing a Parachute. Like them the chin guard did not smash into my face nor did the helmet rotate unil the chin guard hit my face.
As Richard Feynman said
“It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong”
Jezza
legend the helmet will rotate around your head until the chinbar hits your face given a seizable impact.You head will be moving away from the rest of the helmet so it offersno support
That is utter Pish
Giro, Met, Specialized and many others have been building full facers and the switchblade type for many years.. the head is locked into the upper helmet.by retention systems.
it all works as a package.. the chin guard is designed to deflect mainly and partly transfer force into the main helmet.
soulrider - try doing the rotation test I suggest - I bet you will be very surprised how far the helmet can rotate. Go on = please try it and report back.
Better than using gravel to rotate your face. Which is the alternative.
I suppose gloves are pointless too? Mine certainly don't have 2" of padding on the palms. I'd rather crash in shorts than naked too, even though they're utterly worthless at reducing impact and undoubtedly untested.
Don't let the obvious stand in the way of a good lecture though. Please carry on.
Oh well, what a palaver. I bought it to protect my bonce like a open face would do, plus some extra protection on top of that.
Anyway-
Will the Met Parachute do more harm than good?
*cracks knuckles*
TandemJeremy - Member
You are saying a chin guard has a negative effect unless it has EPS, yes?
No - point out where I said that. Read what I said
You implied it by saying as below - even if you didn't my point still stands on what you said.
The chinbar is not tested as a part of standards testing and contains no EPS so will do little to take the energy out of impacts
But you previously said Coulthard's helmet was effective and other full facers not, because it's chin-guard is close to the face, yes?
No - again thats not what I said Coulthards helmet is an interesting design that attempts to answer some of the criticisms of conventional helmets
Fair enough - see how I AM UNDERSTANDING WHAT YOU ARE EXPLAINING ❓
Those appear to contradict one another (as I've made clear already on this thread, and you've ignored, so don't patronise me, sonny).
Its your lack of understanding both of the basics of how helmets work and you lack of understanding of my point that leads you to be confused. How can I explain something I have not said?
You have yet to demonstrate that I do not understand how helmets work (I certainly don't know how you work).
Further, You'v also said that a helmet will spin round until the chin-guard hits your face. I just don't see how that can happen if it remains strapped to your head.You don't see you it can happen Just try it by hand - you will be amazed how far a helmet even with eh straps done up properly can move on your head.
Try this with your XC helmet. put it on as normal. bend your neck forward and grab the back of the helmet and try to rotate it off forwards - see how far it moves
Just did. No it won't, it will hit your neck.
So yes - I was absolute;y correct eh first time - its an utter waste of my time to try to expalin anything to you
No you weren't 🙄
Seriously, if you have such a low opinion of me or contempt for me, why even engage me, if it upsets you so much ❓
You two are engaged now?
Should I buy a hat?
*hums "the circle of life"...*
Should I buy a hat?
Only if it has a chinguard.
Tinfoil one might be best druidh
Is it bed time already?
Given up eh? 🙄
Mummy's calling me to bed now.
TandemJeremy - Membercynic al - I know from attempting to explain to you on this thread and on many others that it is a fruitless task.
I have given you an explanantion on this thread but you reject it completely without any reasoning or understanding.
You will NEVER accept any explanation I give, you will attempt to find fault in anything I say, its an utter waste of my time and effort discussing anything with you.
Proven I believe
Yes that's right, ignore all of what I post and claim I'm not listening.
Hypocrite.
More personal insults. You really are a very bitter and nasty man.
There is nothing to answer - you claim I say things I do not, you claim that me saying "contains no EPS so will do little to take the energy out of impacts" actually means "has a negative effect unless it has EPS, "
Enough of the foreplay you guys and just get jiggy, you know you love each other really.
the pair of you need a slap.
edited
WTF do you expect when you respond like you have? Can you see how you come across?
Not at all, I barely GAS About this crap, only just enough to give myself a laugh on a Monday night. Would quite happily have a laugh with you over a pint about it all if you were up for that.
Please don't mis-quote me for your own ends...I said
You implied it .... even if you didn't my point still stands on what you said.
with a helmet strapped correctly and the retention system tight there is damn near no movement
even swinging on it..
Do you think there's any way out of this thread that won't leave both of these guys looking like raving lunatics?
Ah **** do I look like a loon already?
You're expecting them to come out of it looking better than when they went in? 😯
There just sorting through a few issues, normal service will resume in a day or two, been great reading.
Thanks lipseal, I'm glad my works finds an audience - but this [i]is[/i] normal service 😡
aracer, I assume I'm always starting at rock bottom, only way I can go is up.
did you two go for a pint then?
He appears to have declined my invitation.
Wow, this is still kicking off 8)
Soooo, does anyone actually [i]know[/i] anything about PPE for biking or are most of these :facts: just 'something I read somewhere'
I can't actually work out what the TJ roatation test is as the description is quite loose...
...but my simple old Specialized XC lid has almost zero movement in any plane when the straps and retention system are correctly fastened so I join the people who do not agree that a chinguard (on a correctl fitted and fastened helmet) will rotate sufficiently to hit your face.
I can't understand the argument that without EPS there is no protection. If this is correct then every helmet worn on every building site around the world is not providing any protection, however I would much rather a brick fell on my head wearing a hard hat than without.
but have you rotation tested your hardhat bigjim?
No?
Idiot. 🙄
That's because it's not an argument (objective, interactive discussion of established data) but a viewpoint(subjective, monologue exposition of third party opinion)
The only thing to remember is 'it's your head, protect it how you wish'
I'm fortunate enough to never have had a potentially life threatening head impact but my helmet has saved me from innumerous medium level injuries, mainly of the '****ted in the face by an overhanging branch' variety and made several tumbles a 'dust yourself down' job rather than a 'ooooh that looks nasty' incident
No?
Idiot.
😆 No but I have 'tested' three helmets without face protection and been very glad of their presence. Been lucky not to land on my beautiful face yet.
I've had one bad one and it wasn't much fun - I recommend sticking to the low flying bracnhes!
Hilldodger - the point is - and it is a fact - that the eps is the main mechanism that reduces the effects of hard impacts. At no point did I say it offers [b]no[/b] protection without the EPS - what I actually said was
This is why construction type helmets are not used. This is why a chinbar with no eps is limited in how well it will work as without the EPS the largest component of impact protection is absent.contains no EPS so will do little to take the energy out of impacts.
How do helmets work?
Helmets are normally comprised of four elements; a rigid outer shell, a crushable liner, chin straps or a retaining system and fit or comfort padding. The rigid outer shell when present adds a load-spreading capability, and prevents objects from penetrating the helmet. It's kind of like an additional skull. [b]The liner[/b], usually made of EPS (expanded polystyrene) or similar types of materials [b]absorbs the energy of an impact by crushing[/b]. The chin strap when properly buckled and adjusted along with the fit padding helps the helmet remain in position during a crash.
Helmets work kind of like a brake or shock absorber. During a fall or crash a head is traveling at a certain speed. Since the head has weight, and is moving there is a certain amount of energy associated with the moving head. When the helmet along with the accompanying head impact an unyielding object; a rock, a wall, a curb or the ground the hard shell starts by taking the energy generated by the falling helmet (head) and spreads it over a larger portion of the helmet, specifically the internal foam liner. [b]The foam liner then starts to crush and break which uses up a lot of the energy[/b], keeping it from reaching the head inside. Depending on how fast the head is traveling, and how big, heavy and immovable the object is the faster the head slows down, and the more energy is present. In short everything slows down really quickly. A helmet will effectively reduce the speed of the head by breaking and crushing which reduces the amount of energy transferred to the brain. The whole process take only milliseconds to turn a potentially lethal blow into a survivable one.
Snell foundation
http://www.smf.org/faqs.html#9
So by the same argument you are saying construction helmets do little to take the energy out of impacts?
Yes. They spread it around and the flexing will take some - but construction type helmets are designed for impacts are much lower energy that bicycle ones
Helmets designed for lesser impacts do not necessarily have foam inside. Some are just hard shells with a suspension headband that provides the fit and keeps some space inside for air to circulate. Construction helmets are of this type, and do a fine job when somebody drops a brick on your head or you bump hard against an overhanging steel beam. Just don't fall off a bicycle with one, since they will not handle the impact of falling on pavement.
http://www.bhsi.org/general.htm
Tj nothing in that excerpt discusses chin-guards.
energy absorption must be different in chin-guards.
+ the numerous points I made above that you are choosing to ignore.
Well I don't know much about the pointless bickering that is going on but I own a parachute and three other of my mates also bought one after having to take a rider buddy to A&E when his front wheel slipped off the boardwalk on one of the afan trails (wall or whites I forget which)
As he went down the side of his face scraped along the chicken wire put on it for grip and he is now scarred for life.
As far as I'm concerned it is a wise investment if you value your good looks and occassionally come off the bike. I'm surprised more manufacturers don't produce them.
You do feel like a tool wearing it though.
Yes, well done thats what I wanted you to pick up on - the hard material transfers most of the energy, and absorbs some, so what the face part of the Parachute does is transfer the energy from the chin into the rest of the helmet to be distributed and absorbed.
Aye bigjim - the energy has to go somewhere. Yes the parachute will be effective against small impacts. However the energy has to go somewhere - and a faceplant in a parachute with a high impact speed that energy will still go into the head somewhere as there is no eps getting crushed to actually absoeb the energy. The flexing of the hard shell will not absorb forces of the magnitude involved when you hit a tree flat out. Thats when you need the eps
Its difficult to see who's showing themselves up worst here, Al or TJ.
2 grown men battling out some pointless debate on the internet.....
oh dear 😐
I don't think you can state anything about that without knowing how the chin guard part is mounted on the helmet - it might be quite well engineered so that the energy is transferred into the EPS and/or through the inner nylon cage effectively. My mate has one so I'll have a look at the weekend.
But anyway it is clear the helmet will provide face protection which is why people are buying them, and based on the users in this thread they do work.
Surely, a chin guard is not designed to work the same way as the rest of the helmet, otherwise it would be like a close fitting beard type thing of the shape that industrial designers called Oswald would sport? Which would clearly be ridiculous.
As I see it, the main inner shell of the helmet crushes when pressed betwixt your head and a hard surface (tree trunk/rock/frying pan) and the energy absorbed in crushing the polystyrene is what saves your noggin' from splitting open like a coconut.
The chin guard is designed not to deform, but to create a crash barrier between your face & the ground. Sure it'll deform a bit, but that is a by product of the impact.
The chin guard keeps your delicate Nivea soaked face away from the jagged hard bits that want to rip it to shreds. What happens to the energy is of secondary importance, as far as the chin guard is concerned - presumably the impact shunts the helmet & your head backwards/sidewards until the rest of you catches up/stops. Even if the helmet decides it wasn't put on properly & the chin guard hits your face as a result of the whole lot moving, then at least you are left with an interface which consists of face/plastic chinguard/rough, scrapy stuff, compared with face/rough, scratchy stuff.
A mate of mine has one and it saved his features quite well at Penmachno once when he sailed over the bars at speed. There was quite a lot of chin guard scrape-age, but his features remained intact. He is unwilling to repeat the crash with a normal helmet to compare the results, which quite frankly is a bit selfish, if you ask me.
Deal with it people, everyone is wrong other than TJ (of no ff helmet experience)!
