meccano-style fixin...
[Closed] meccano-style fixing strips - proper name for googling ?
longish pretty strong steel strip with 'oles drilled in it
what are they called in the shops ?
Posted : 16/06/2013 8:01 pm
We call it galvy banding at work. Probably a much more technical term for it though.
Posted : 16/06/2013 8:03 pm
http://www.screwfix.com/p/galvanised-band-12mm-x-10m/18298
Or maybe not
Posted : 16/06/2013 8:04 pm
cheers, nm - seems "galvanised band" (I'm posh, see) is something flexible that comes in rolls. I'm after a 2-3 foot rigid strip really
Posted : 16/06/2013 8:05 pm
I see. In that case I shall take my common galvy banding and bugger off elsewhere ๐Ÿ˜‰
As for the other stuff I have no idea.
Posted : 16/06/2013 8:10 pm
can you not just go to an engineering place and get some strips of the size/thickness you want drilled
Posted : 16/06/2013 8:12 pm
Wall plate straps are pretty rigid.
http://www.screwfix.com/p/simpson-strong-tie-light-restraint-strap-1000mm-flat-pack-of-10/68346
Anything flat will have a bit of flex so you might need angle like dexion.
Posted : 16/06/2013 8:18 pm
[url= http://www.tecties.co.uk/tthds.html ]Something like this[/url] might suit - cut to order, so should be able to specify a simple straight length.
Posted : 16/06/2013 8:20 pm
Dexion? Though didn't they go broke yonks ago?
Posted : 16/06/2013 8:24 pm
http://www.toolstation.com/shop/Construction+Materials/Builders+Metalwork/Heavy+Duty+Strap+Flat+30+x+5+x+1000mm/d210/sd2797/p50096
you can buy them seperately and free delivery over a tenner.
Posted : 16/06/2013 8:32 pm
well done [i]everyone[/i] !
So some sort of builders metalwork is what I'm after. Once I've worked out how I'm going to do what I want I can buy a couple of bizarrely named bits of mild steel
(is toolstation big with the ninja crowd ?)
Posted : 16/06/2013 8:42 pm
