Maxxis Advantage tu...
[Closed] Maxxis Advantage tubeless?
Anyone set these up and had luck?
Posted : 17/06/2012 9:08 pm
Yep- I have, but with normal Advantages, not tubeless specific though. Work well but leak air ever so slightly which isn't too much of a problem ๐Ÿ˜€
Posted : 17/06/2012 9:17 pm
Folding 2.4 Exos went up pretty much instantly for me, like a TLR tyre.
Posted : 17/06/2012 9:19 pm
Run them on Crossrides with a Stans kit for 2 years. No problems at all. No more leaky than any other tyre I've used.
Posted : 17/06/2012 9:24 pm
I'm running one as a front tyre on a Stan's Crest rim. No problems, but not the easiest to inflate as they have baggy lightweight walls. I use sealant so no significant issues with leakage.
Posted : 17/06/2012 9:31 pm
Advantage Exceptions here. No probs until the sealant dried out, then it was Mountain rescue to the rescue! ๐Ÿ™„
Done a 2.1 folding 60a eXCeption on a Mavic XM719 with a stans standard rim strip. Needed to use a compressor to seat the beads, once seated had zero problems in use.
Posted : 17/06/2012 9:32 pm
Easy peasy on Stans ZTR355s. Inflated first time with a track pump and hold air no problem.
Posted : 17/06/2012 9:33 pm
lovely, will give it a go.
hopefully no mountain rescue needed. . .
Posted : 17/06/2012 9:46 pm
I had no joy
Posted : 17/06/2012 10:14 pm
no problems with mine
Posted : 17/06/2012 10:38 pm
I have an ADvantage 2.1 foldable. I used it a few times for the front on my hardtail, on a ZTR Crest rim. It worked well and I felt it grips better than a 2.4 WTB Mutano I tried to convert the advantage to tubeless and (to my surprise) it popped off the rim (twice). This is my first conversion so I may have done something wrong however the guy that helped me with the other wheel (ZTR Alpine) said that I put Stan's tape nicely and the tyre should have not popped off the rim. It popped at about 50-60 psi so maybe it was my fault?
before it popped it seemed to fit nicely but I am still a little surprised. It is my first tyre that pops off the rim, ever.
Posted : 11/04/2013 12:59 pm
I ran Exos tubeless, no problem at all.
Posted : 11/04/2013 1:23 pm
For balance, I found them hopeless on Stans Flows
Posted : 11/04/2013 1:27 pm
