Maxxis advantage an...
[Closed] Maxxis advantage and mavic 819s
[#390503]
anyone use this combo? any problems with inflation or burping with the tyres being non UST
Posted : 14/03/2009 8:20 pm
bump
Posted : 16/03/2009 8:48 pm
I have a Maxxis madusa/717 rim set up.None of which are tubeless specific and work a treat.I used the DT swiss conversion kit and it works well.Easy to use.Run tyres as low as 28 psi and have never burped.The only problem i seem to notice with the tyres run at such a low pressure,is the alarming tyre wear..avoid roads if you can.
Posted : 16/03/2009 9:16 pm
the 819 rims have a ust bead - thats why i am asking. cheers anyway
Posted : 16/03/2009 9:21 pm
Hi Rob, I've used them on mine but the sidewalls were too thin and after a few burps and pinches i gave up. I was speaking to Jon of Justridingalong whilst out on saturday and he said Maxxis have now thickened the sidewall to something in between a single and a double ply high roller so they may be perfect!
Posted : 16/03/2009 9:36 pm
I was just giving you an insight into what non ust maxxis tyres are like in my experience.If they work well on my non ust rims i would imagine they will be no probs with an 819 rim.Good luck
Posted : 16/03/2009 9:49 pm
its the bead hook compatibility that i am after rod (not being rude)
Posted : 16/03/2009 9:53 pm
Is a normal bead more likely to burp on a UST rim? I've only just bought some UST rims and was planning to run non-ust ADvantages myself...
Posted : 17/03/2009 11:46 am
