Maxle lite with pro...
[Closed] Maxle lite with pro 2 movement / play
[#4872062]
Brand new RS revelation with maxle lite, brand new Hope pro 2 evo's. Play in my front wheel. Only slight, but very noticeable. Seen a few old threads on this but I've not found a solution yet... how can I solve this problem?
Posted : 14/02/2013 10:23 pm
check that the bearings are properly seated/circlips fitted correctly for the adaptors.
Posted : 14/02/2013 10:44 pm
New bearings. Seriously.
I had the same on a brand new wheel. Rode it like that for ages. Checked the bearings and one had very slight play, barely noticeable, but at the wheel rim there was a bit of movement.
Finally got round to putting new bearings in last week and the play has gone.
Posted : 14/02/2013 10:50 pm
I've got some 15mm adapters from hope but these didn't come with circlips. Should I be using circlips with them? I just pushed them into the hub.
Posted : 14/02/2013 11:30 pm
15mms dont use circlips (on standard pro 2) they push in like the 9mm, only 20mm need circlips.
Posted : 15/02/2013 12:09 pm
