20mm maxle
[Closed] 20mm maxle
[#4872067]
why why why does it KEEP coming loose anyone fixed this?
Posted : 14/02/2013 10:25 pm
Never had it happen tbh- which version is it?
Posted : 14/02/2013 10:36 pm
its on a lyric didn't know more than one version.
every time i push it hard its loose! driving me mad
Posted : 14/02/2013 10:38 pm
Not being funny or anything but...are you doing it up properly? Have one on a Lyrik with no issues. Tighten into the fork threads by rotating whole axle, then use the qr type skewer to lock into place by rotating lever only and expanding the 20mm tube into the threads...
Sure you are...just that I've never had any issues and can't see how you would with the design.
Posted : 14/02/2013 11:14 pm
How hard is the lever to close? You may need to adjust it so there's a touch more tension, the latest ones need the lever opened to reveal a 2.5mm allen key fitting, tighten this a click or two.
Posted : 14/02/2013 11:29 pm
Are the threads ok? A friend stripped theirs and have to buy a new axle. Have you adjusted the nut at the opposite end to the qr? Take it al to pieces and check nothing is obviously broke, it sounds like something is.
Posted : 15/02/2013 8:00 am
The Maxle I had on the Pikes were rock solid and never came loose.
The Maxle-Lite on the Sektors is a joke, comes loose after a couple of days and that's taking it off and re-fitting it between trails.
Sorry not sure of the fix but i'm interested to hear of anyone that does have a fix.
Posted : 15/02/2013 9:32 am
I've got one on my Float 36's,its never ever come undone,you're doing something wrong..
Posted : 15/02/2013 10:05 am
