Max Comp pivot bear...
[Closed] Max Comp pivot bearings or not ???
[#7212626]
So its time to replace my Trance pivot bearings, so what do I put back in?? All OEM bearings are Max comp(no bearing cage all balls). I see some bearing replacement kits from those guys selling on ebay only seem to include 4 (expensive ones) and the other 6 normal ie not max.
So what do you use all Max or Mix ?
Oh and are Stainless worth the extra ??
Also what grease is good for a bit of extra life ?
Posted : 23/07/2015 10:32 pm
