Anyone run Mavic 72...
[Closed] Anyone run Mavic 721's tubeless?
[#7212611]
Just purchased a set, and I was wondering if I could run them tubeless? They would be on my downhill bike with Magic Mary SG vertstars which I hear work well with the tubeless system. They just seem quite narrow, and haven't really heard anyone else running them tubeless...
Many thanks
Henry
Posted : 23/07/2015 10:29 pm
If I can get my old 717's to run tubeless which are narrower (17mm rather than your 21mm) i'm sure you'l be fine. I used one layer of stars tape then 2 layers of Gorilla tape for a tighter fit.
Posted : 23/07/2015 10:32 pm
Just whap some joes rim strips on top of the cloth tape and away you go
Posted : 23/07/2015 10:55 pm
 al
I find tyres blow off, or roll off, with 721s when tubeless. In the end I ghetto'd mine and they've been fine since.
Posted : 23/07/2015 11:17 pm
I ghettoed mine and they were fine until the bike got stolen. Had a 721 on the back and a 719 on the front. Both worked well.
Posted : 24/07/2015 7:41 am
I run my Mavic 321s ghetto tubeless with no problems.
Posted : 24/07/2015 8:01 am
I've run them tubeless in the past, with a rimstrip.
Posted : 24/07/2015 9:20 am
 core
I've got 521's tubeless - with cloth rim tape and stans rim strips (think it's the rhino strip you need).
Only word of warning is get tyres with a decent sidewall, specialized control carcass isn't really strong enough for a rim of that width in a 2.3, they roll over too much and burp, a lot.
Posted : 24/07/2015 9:24 am
Yes I've just converted an EX721 using Gorilla Tape ghetto method. Using it with a Nobby Nic.
Posted : 24/07/2015 9:25 am
I had zero issues with hans dampf or nobby nics on en521 with stan's rhino (?) strips
magic mary on a different rim was easy to get on the rim, but difficult to inflate. I had to resort to seating with a tube overnight.
rock razor on the same rim was difficult to get on the rim, but it went up first time with a track pump.
Posted : 24/07/2015 9:31 am
 tomd
Yes, but with stans rim strips. Never had any problems.
Posted : 24/07/2015 9:42 am
Gorilla tape helped it work beautifully for me. Tyre choice is important in my experience too
Posted : 24/07/2015 10:08 am
Gorilla tape worked perfectly for me too.
Posted : 24/07/2015 1:34 pm
I have run them tubeless with specialized an Michelin tyres, not tried schwalbe though.
I actually have one I was considering building onto an old hope hub for the HT... Wet evening I might go fish it out of the garage and start now. Cheers for the reminder...
Posted : 24/07/2015 2:19 pm
 Sui
Yep, my 721's are tubeless (well front is as i've been a lazy sod and not taken the tube out the rear). Used hte Joes no flats kit, worked really well and very easy. I agree tyres do seem to roll a bit more when tubeless on these rims..
Posted : 24/07/2015 2:32 pm
