Mavic Crossride - 6...
[Closed] Mavic Crossride - 6 bolt or centrelock?
[#2252335]
Hi,
Got mavic crossrides on my zesty - looks like 6 bolt rotor fitting but cannot how rotors come off (no access to the bolts!)!? 😳
I think they may be then supplied with an adaptor....in which case if I need new rotors do I go for 6 bolt fittings or centrelock?
Thanks,
Bikey
Posted : 04/12/2010 12:15 am
 juan
6 bolts why you ask myself well simple
6 bolt rarely become loose, CL less rarely.
There is 3 different standard of centerlock.
In the unfortunate event one of the 6 bolt get loose, most of the multi tool have a torx wrench to screw it back.
To be fair I would have much prefer shimano get something done about the stupid cones and cups hub, rather than do something as useless are creating a need when everything was fine.
Posted : 04/12/2010 12:23 am
there is a lock ring that a shimano bottom bracket tool that will fit it to remove it.
Then your right there is an adapter which enables you to use a 6 bolt rotor of your choice.
hope that helps?
Posted : 04/12/2010 12:26 am
Great stuff that answers the question - cheers guys 😀
Posted : 04/12/2010 12:39 am
I thought it was the cassette removal tool.
Posted : 04/12/2010 1:13 am
Spline tool's for Shimano, Mavic use a HT2 tool and a 6 stud adapter with a 6 bolt disc.
Posted : 04/12/2010 9:09 am
You learn something new etc.
Posted : 04/12/2010 5:34 pm
