Mavic Aksium buzzin...
[Closed] Mavic Aksium buzzing freehub
[#10990229]
You know the sound that you get when a loose bearing moves too fast and it starts to rattle around the spindle? That, when freewheeling above about 25mph. Anyone else had it?
Obv a new freehub would fix it but I think the rear bearing is a plastic sleeve and develops play. So a bit of lube in it should extend the life? Anyone got experience of these?
Just sprayed some grease in and I can't get it to make the noise again, on my street at least.
Posted : 04/01/2020 4:30 pm
Is this the well known mavic death squeal? If so, strip down and regrease.
Posted : 04/01/2020 4:33 pm
does Your free hub have vertical play? I.e. can you wobble it? If so I believe some Mavic hubs have a plastic spacer that can wear. Cheap and easy to replace if it is and I think you might be able to get alloy replacements.
Posted : 04/01/2020 4:43 pm
Very slight vertical play yes.
Possibly the well known 'death squeal' I'm not sure. I guess it's worth a strip in that case.
Posted : 04/01/2020 6:29 pm
Do you just pull the end cap off to disassemble?
Posted : 04/01/2020 6:43 pm
Assuming it's the classic Mavic freehub design, you can buy replacement bushings - and oversized ones to cater for advanced wear - but only from the States, see Hub Doctor and similar on eBay. Greasing it might quieten it down for a bit, but eventually you'll need to fit a new freehub at around 35 quid.
Edit: a tenner with free shipping from the US on eBay
https://www.ebay.co.uk/itm/STD-Mavic-Crossmax-Freehub-BUSHING-Freewheel-Cassette-plastic-hub-bearing-wheel/250661501006?hash=item3a5c96f84e:g:Ul4AAMXQaBtQ9c7C
Posted : 04/01/2020 6:44 pm
Don't just pull it off, it needs to be rotated at the same time to compress the pawls and stop them catching/damaging the bushing.
Posted : 04/01/2020 7:08 pm
'Google + Images '
Posted : 04/01/2020 7:10 pm
Mavic freehubs occasionally need a service; you undo, slide it off, clean it then add some light oil and reassemble; look it up...
Posted : 04/01/2020 7:44 pm
Mavic freehub sercive:
IN my experience, once the howl of doom had started then the bushings were gone and it was new freehub time anyway. Hope you have better luck with yours.
Posted : 04/01/2020 9:42 pm
^^^^^^^^^^^^^^^^snap^^^^^^^^^^^
and i have a bnib one looking for a new home
Posted : 04/01/2020 9:44 pm
It only needs to do a couple of rides including tomorrow AM, I'll order another one asap now I know what's going on.
Posted : 04/01/2020 11:38 pm
Well it was ok today for 3 wet hours after a bit of spray grease.
Posted : 05/01/2020 5:40 pm
