Is it possible to mount an M8100 shifter to an M785 brake lever?
Posted : 17/06/2020 1:11 pm
Not officially. The M8100 uses the new I-spec EV attach-things-to-brake-levers standard where the M785 uses I-spec II which is completely different. Dunno if Problem Solvers has made a doohickey that solves this problem yet...
Posted : 17/06/2020 4:28 pm
Isn't M785 I spec b ?.
I spec ll is m8000.
Posted : 17/06/2020 6:24 pm
£30 for a SLX SL-M7100 band-on... pull apart stick XT internals inside and not have to bother with i-spec again
Posted : 17/06/2020 8:09 pm
Wolftooth I spec ev to ispec b, the weird looking one with the grub screw, better off swapping for bar mount shifter.
Assuming you have I spec ev one.
Posted : 17/06/2020 8:14 pm
Thanks
Posted : 18/06/2020 1:13 am
