New pedals
[Closed] New pedals
[#11253555]
Hello
I'm about to put new pedals on a bike for the first time. It seems pretty easy to me, but that's a mistake I've made before.
Is there anything I need to think about other than "take off old pedals, put on new ones"?
Posted : 17/06/2020 1:50 pm
Don't forget the threads are different. From memory the DS (right hand) crank will be a 'normal' thread I.e. Lefty loosey, rightly tighty. The non DS will be reverse of this.
Make sure you put the right pedal on the right side.
Hth
Posted : 17/06/2020 2:00 pm
thanks bikecurious
I'm mostly expecting replies saying "bang frozen sausages into the seat post", plus something hilarious from PerchyPanther that I'll kick myself for not thinking of.
Posted : 17/06/2020 2:01 pm
Is the bike upside down or right way up?
Posted : 17/06/2020 2:02 pm
Grease the threads.
Check and then check again that the right pedal is going onto the right side.
Screw in gently, it should go in most of the way without a spanner, if it doesn’t then back off and start again. No not force it as this leads to cross threads.
Posted : 17/06/2020 2:03 pm
Thanks all, pedals on.
I'm a little disappointed that no advice mentioned sausages or bumming pets, but the job's done.
Posted : 17/06/2020 5:41 pm
Grease on the threads +1, without it, it's shocking how much brute force you may need in the future to remove them and possibly strip the crank thread in the process.
Posted : 17/06/2020 5:44 pm
