Mass suicide attemp...
[Closed] Mass suicide attempt by commuter cyclists.
Speeder - ...filtering right and as such should have an expectation that there's no-one to his left or if they are there illegally, they have the sense to have gotten out of the way.
Well this is the point that some of the people here are trying to make. The driver is surrounded by cyclists and should adjust his driving to suit, he couldn't reasonably expect his left to be clear, he should be as sure as possible. He obviously didn't adjust his driving and certainly backed that up with his ranting afterwards.
Posted : 07/07/2017 10:55 am
So when can he expect his left to be clear? because even when he does get to the curb there could still be a cyclist right against his bumper.
Posted : 07/07/2017 11:07 am
Even though he was largely without blame if he finds himself in the same situation again then he could alter his behaviour by maintaining a constant speed through the pinch point rather than accelerating into it.
Or he can just keep accelerating into pinch points since there is nothing strictly speaking illegal about it
Posted : 07/07/2017 11:12 am
It's not about where a cyclist *could* be, it's about where they are LIKELY to be.
Cyclists are likely to be riding on the left by the curb, like they are on pretty much every single road in London. He's driving a large lorry, he should be aware of this. Accelerating away from the junction and moving to the left, leaving no gap near the curb, is not good driving, especially when that's where the blind spot of the lorry is.
Even if the cyclist wasn't in the left turn lane acting like an idiot, there could be other cyclists there.
I can't believe people think the blind spot has no effect here. Even if someone makes a mistake, you can't just drive into them when you can see they are there, so removing the blind spots would have an effect in reducing accidents.
Posted : 07/07/2017 11:18 am
 dazh
Haven't read the whole thread, got the gist after page 1. The usual anti-cyclist stuff you see on here which is very peculiar for a cycling forum. Yes the cyclist was bloody stupid, but the truck driver knew there were loads of cyclists around (half a dozen of them cycling off in front of him), yet thought 'sod'em, they're not obeying the rules of the road, so I'm in the right and don't have to care'. If I'm driving and there is a blind spot, I assume the worst and drive accordingly rather than piling on regardless, which is what the driver did here.
Posted : 07/07/2017 11:43 am
STATO - So when can he expect his left to be clear? because even when he does get to the curb there could still be a cyclist right against his bumper.
Do what the tipper driver is doing in the streetview link that Speeder so helpfully provided. Move over into the merging lane (slow to let the equally impatient motorists stream past on the right if necessary) to leave some space at the curb just in case. Rather than carry on regardless and *hope* that you aren't going to grind a cyclist under your wheels.
Posted : 07/07/2017 11:47 am
No he can't .... in that same situation again he has cars on his right and behind as well.
The cars on his right can't see the cyclists and the cyclists can't see the cars on the right. The HGV driver has to consider the cyclists [u]and [/u]cars on his right [u]and [/u]cars coming in the opposite direction.
He doesn't have the luxury of exclusively watching some cyclists ...
Posted : 07/07/2017 11:57 am
Yes but in the next time it could be a slower cyclist, so it would end exactly the same way.
There are only 2 alternatives.
1. Remove blind spot, they shouldnt be there. But they are, infact in modern cars they are getting pretty huge too for drivers that dont bother to move their heads.
2. Slow significantly before he moved left, so that anything that had stayed in his blind spot was now moving much faster and travelling out of it (while also watching to make sure nothing went into it).
But of course 'this is London' so if he had slowed to move left you could expect the camera guy to dive up the inside and expect the driver to actually stop, or you would have had a load of cyclists going round his right side and then cutting infront.
Posted : 07/07/2017 11:58 am
The difference there is that the tipper driver is driving through the junction on green having come from a single file of traffic with a clear idea of what's going on around him not starting off from the inside lane from a standstill with a gaggle of impatient & mostly invisible cyclists illegally situated next to him.
FFS I give up - sense obviously isn't as common as I thought, even on here.
Radar - HGVs need radar - that'll solve it.
Posted : 07/07/2017 12:00 pm
we're all cyclists here and that generally we're siding with the big bad truck driver should tell you something.
that almost always happens on here.
What it tells me is that even cyclists are not sympathetic to cyclists.
Posted : 07/07/2017 12:02 pm
Whether or not you criticise the HGV driver, I think most or even all of us think that the primary responsibility for the accident lies with the cyclist, and that the cyclists using the filter lane were all in the wrong.
Given that most of us are experienced cyclists, I wonder how we would behave in those circumstances, after a period of time commuting by bike in London:
a. Gradually copy the other cyclists because of the difficulty of going against the flow and herd mentality (but make damn sure to either be fast enough to outsprint the HGV well before the pinch point, or hold back in the junction until it had passed and then slot in behind it)
b. Ignore the other cyclists and always take primary position behind the artic
c. Go over to the cyclists and tell them that they should not use the filter lane to sidle alongside the artic.
I am fairly sure I would do b., because it's clearly the safest option and I am an extremely cautious rider. I'd like to think I would do c., but I suspect that even if I did that the riders would ignore me and I would give up after one or two attempts.
If so many riders in London and elsewhere are cycling so dangerously, such that they are now no longer just a few bad apples but possibly the majority, how are they to be persuaded to change? The police probably do not have the resources to undertake major exercises on a large enough scale to influence enough of these riders to change. And the riders themselves do not appear to be receptive to being told they are in the wrong (Dunning Kruger effect?).
Posted : 07/07/2017 12:14 pm
not sympathetic to stupid people...
Posted : 07/07/2017 12:16 pm
I'm sympathetic to rucksack man, I'd hate to be in that position of being properly scared for my life but I'm objective enough to see that he brought it all upon himself.
Judging from his actions, attire, gear choice and general sense of awareness, he's not a regular cycle commuter and this has probably put him off for life and that's a shame. One can only hope he's self aware enough to watch the video back and say "I f****ed up there" rather than "that truck driver tried to kill me"
 dazh
No I think most of us think what the cyclist did was bloody stupid. The responsibility though always lies with the person who poses the biggest danger to others, which in this case is obviously the truck driver.
So because he made a stupid decision he deserves to die and we shouldn't be at all bothered about it? 😕
Posted : 07/07/2017 12:19 pm
Cyclist all at fault - that's a left only lane they were in. At least the girl had the sense to notice that there was a huge truck next to here and see the impending danger.
Posted : 07/07/2017 12:27 pm
I just don't think that would actually work for big HGV's....
Assuming 90% of attention is on what's in front a full set of 360 cameras and sensors the remaining attention is then spread pretty thin.
I might be wrong but I think it would simply be an information overload and possibly lead to more accidents with the driver checking various screens.
Posted : 07/07/2017 12:32 pm
We teach children not to step out to cross the road from behind parked cars because it puts them in danger of getting flattened by a car/bus/truck that hasn't seen them - this is just the same. The cyclist has wilfully ridden into the path of an oncoming vehicle from a position where he can't be seen with no regard given for his own safety and I can't fathom how anyone is apportioning blame to the driver. Other than the fact that he's not the vulnerable party.
 dazh
He's driving a massive truck, with lots of blind spots in an urban environment where he knows there are loads of cyclists around, yet he still sees fit to accelerate into a pinch point after seeing lots of other cyclists overtake him on the inside. You don't think he maybe should have though that there might just be more, and slowed down to be sure? The fact that they are stupid and not obeying the rules is largely irrelevant.
Posted : 07/07/2017 12:39 pm
Accelerating when the lights go green? Shocking behaviour!
Posted : 07/07/2017 12:40 pm
The truck driver is responsible in that he managed not to hit any cars or force them into an oncoming bus.
You are looking at this as if it was a 2 party accident.
The HGV driver doesn't have that luxury... which is what a lot of people are missing. The HGV driver has to consider everyone else.
But does he deserve to live [u]at the expense of[/u] a car full of kids on the other side of the road?
Should the driver divert all attention to a possible cyclist when he has cars on the outside and then potentially swerve and knock one into the path of an oncoming bus?
Does the driver of the car behind deserve to die because they are too close if the HGV slams on the airbrakes?
Posted : 07/07/2017 12:42 pm
dazh - Member
No.
I do get where you're coming from but it was the cyclist's accident to avoid. There are 9 other cyclists who managed to avoid putting themselves in that situation either by getting in front or hanging back (or filming) only this guy persisted in staying in the blindspot and then riding into the path of the truck.
Posted : 07/07/2017 12:47 pm
The bloke filming was a bawhair from a similar collision, its only in light of the utter stupidity of the guy in front that his riding doesn't look so bad. This makes his cry of "I've got that all on camera" particularly pathetic.
Posted : 07/07/2017 12:53 pm
Which is cobblers. Ultimately, what governs the rights and responsibilities of all road users is the law and the Highway Code, which exists to tell people what they may and may not do, and so make the roads safer by making people's actions compatible and predictable.
At the end of the day, it is the justice system that is the ultimate arbiter of responsibility under the law, and neither your nor my opinion will count (unless you work for the CPS, or one of us is on a jury). If that accident had resulted in the cyclist being killed, I very much doubt that the driver would have been prosecuted, because it would have been deemed the cyclist's fault.
That is childish logic. Indeed you seem to want to apply parent and child standards of responsibility for behaviour to road users: children are unpredictable and can run out into the road, and parents are responsible for them and have to prevent that and protect them. Grown ups have autonomy and can make their own decisions, but they also have to take responsibility for those decisions and enjoy or suffer the consequences as applicable.
Posted : 07/07/2017 1:01 pm
completely agree - the truck driver would have known that the other cyclists were there but can only assume that they would be smart enough to stay back from the impending danger, like that lady.
Posted : 07/07/2017 1:03 pm
Current situtation - driver looks forward and has to check 8 (?) mirrors.
Future situation - driver looks forward and checks one screen (with mirrors in case the system fails).
What is more likely to result in "information overload"?
FWIW... this is the sort of thing I am talking about
So a drone for every truck then?
Posted : 07/07/2017 1:21 pm
 dazh
Completely agree but IMO drivers of trucks in conditions like that should operate at a higher level of skill, awareness and responsibility. The way he accelerated into the pinch point I wouldn't have done in my car, let alone a truck. I can understand the truck drivers reaction but I would argue that if a truck driver couldn't deal with that situation without hitting a cyclist then they probably shouldn't be driving a truck in a difficult urban environment.
Posted : 07/07/2017 1:32 pm
He doesn't. Our hero with the camera brakes. It the frame of reference that makes the truck look like its accelerated
Posted : 07/07/2017 1:34 pm
It's London mate...
Utterly ridiculous.
Posted : 07/07/2017 1:38 pm
It's not a drone. It's a reprojection of fisheye images from cameras mounted on the front, sides and rear of the car/truck onto the ground plane.
Posted : 07/07/2017 1:40 pm
It doesn't need electronic devices to fix the blind spot issue just a cab at the height of other road users.
Although I would probably suggest that that size of vehicle should be in the centre of a city either.
Posted : 07/07/2017 1:47 pm
Unless the guy who got hit also brakes at the exact same time as the guy with the camera then no, the driver accelerated into the pinch point.
Most likely he was doing that because he had a line of cars accelerating like mad to get to the traffic island before him and cut him off.
Which they were doing because the road design is ****ing stupid. One lane for straight ahead and a full size filter lane would have meant that this probably wouldn't have happened.
Im amazed that people are saying the driver is at all at fault.
typical of todays society imo. Ive hurt myself and it must be someone elses fault....
Posted : 07/07/2017 1:49 pm
 dazh
So in the spirit of accepting I might be wrong, I watched it again a few times. This time with the sound on. Seems to the following exchange is very illustrative of the driver's mindset:
cyclist with camera: 'Mate you knew there were cyclists there'.
Driver: 'I don't give a ****, you were in the wrong lane'.
Can't say I've changed my mind.
Posted : 07/07/2017 1:52 pm
Ah but the driver was accelerating.
From a standstill. Whodathunkit? 🙄
Posted : 07/07/2017 1:53 pm
I don't think anyone is saying the driver is at fault. I'm not sure if it's a road thing or if a society in general thing but there seems to be a need to attribute blame 100% one way or the other in any accident. In reality there's normally one person who is mostly at fault, in this case the cyclist who put himself into a very dangerous position, and the contributing person, in this case the driver who accelerated into a pinch point.
And then there's the environment factor which in this case is a really stupidly designed and dangerous junction which has a filter lane that you don't really notice until you're in it and a two lane into one within meters of the junction which meant the HGV driver was accelerating into the pinch point to stop himself being cut off by a line of cars racing up on his right.
So, main factor, cyclist being stupid. Contributing factor to that was the driver accelerating into the pinch point. And the contributing factor to that was the line of cars racing up his right side. And the contributing factor to that was the stupid ****ing road design.
Posted : 07/07/2017 2:00 pm
Look at the video again. He was maintaining a constant speed/accelerating slowly moving across the junction. Then there is a sudden increase in his speed relative to the cameraman and the rucksack guy as he enters the pinch point. He was probably trying to beat the cars trying to cut him off from his right.
Posted : 07/07/2017 2:03 pm
Maybe it's just me, but I tend to try and avoid running people over regardless of who's at fault.
Posted : 07/07/2017 2:10 pm
My OH's car has multiple sensors and rear camera.... the first thing I do when I drive is turn them all off (All the times I've ever driven her car only ever driven to the local sainsbury's that is reverse parking in very tight spaces )
I'm perfectly capable of putting the car in a gap 6" longer than the car but no way can I do it with sensors going off everywhere and a distorted camera view.
My OH however struggles to stick it in a gap 6' longer than the car either with or without sensors/camera.
I'm not saying it can't work... but I am sceptical... Most HGV drivers are experienced and know the size of their vehicle - to take the parking analogy more like me than the OH...
Posted : 07/07/2017 2:22 pm
[quote="Driver:] 'I don't give a *, you were in the wrong lane'.
I think the driver is understandably quite shaken....
I think you are choosing to believe the driver is saying it's OK because they shouldn't be there ...
I believe the driver is saying he doesn't Fing care if it's London etc. that he didn't see the cyclist [u]and the cyclist should know this[/u] because of all the awareness campaigns...
Posted : 07/07/2017 2:26 pm
whether he did or didn't ...
He was probably trying to [s]beat[/s] not crush the cars [s]trying to cut him off from[/s]on his right
Posted : 07/07/2017 2:28 pm
well it got past the cyclist it hit and i think we can all agree things from stationary accelerate away from a stationary start.
Why you calling him a hero? all it does is make me question your impartiality.
Posted : 07/07/2017 2:31 pm
 dazh
I'm believing what I heard, not what I want to hear because it fits with my opinion. It's quite clear what he said, and what he meant, so I don't know why it's up for debate.
Posted : 07/07/2017 2:32 pm
When the cyclist started shouting (ie the first moment he had any idea the bloke existed) the driver swerved away from the curb. His reaction was what I'd expect from someone that's come that close to inadvertently killing another person. Just because he knew he'd ridden up the inside (obvious) doesn't mean he tried to kill the guy to "learn him".
Posted : 07/07/2017 2:33 pm
I think the driver is saying...
"I don't want your death on my hands just because you're an idiot"
Posted : 07/07/2017 2:37 pm
Page 10 / 11
