Marzocchi Mx Lo - S...
[Closed] Marzocchi Mx Lo - Stupid Lock-Out Mechanism!
Had a set of Mx Lo forks for 9 months now and the Lock-Out cable has stretched enough that when i release the lockout it doesn't spring back. The adjuster screw is screwed right out but there's still too much slack in the cable.
Trouble is, the screw holding the cable in position on top of the forks is a 1.5mm allen key head and the tiny allen key has rounded off the bolt hole.
Don't own a drill, so can't really drill it out.
Anyone else had this? Is there somewhere i can get a replacement cap and Lock-Out mechanism?
Cheers, Jaeg
Posted : 22/07/2009 3:59 pm
Tap in a torx driver? Use an easy out? neither requires drilling ( well the easy out might)
Posted : 22/07/2009 4:04 pm
post a pic so we can;
a)ridicule your ham fisted'ness
b)suggest a solution
Posted : 22/07/2009 4:16 pm
