Any tried them? Any good?
More specifically, anyone tried them on a 27.5 Trance?
Posted : 18/05/2015 12:03 am
I have the 350 CR they are very stiff plush and consistent.
Posted : 18/05/2015 12:16 am
I assume the added "C" just means they have adjustable compression?
Posted : 18/05/2015 10:42 am
Well, I'm not sure if the damper is different in other ways is still uses a DBC cartridge. The spring side is very different as the R is a coil fork with air preload, the CR is an air fork with a coil negative. The AER unit is a extremely linear spring so I ended up adding oil to make it a bit more progressive similar to adding tokens to pikes or spacers in a shock air can. This wouldn't work for the R though as it is a coil fork.
Posted : 18/05/2015 12:23 pm
