Hi! Aluminium frame, rubber/plastic downtube Protector.
Most of it is still stuck very well, but the corners are lifting and it looks tatty. What glue would work and won't damage the frame ?
Posted : 14/06/2023 9:00 am
Silicone sealent? You could wipe the exposed parts down with somehting to clean the edges and the frame (Isopropyl maybe) and then put the silicone under the protector and smear a bit over it as well.
Posted : 14/06/2023 10:10 am
Worst presidential campaign strap line ever!
Posted : 14/06/2023 10:12 am
only1mikey and danposs86 reacted
Thanks willard!
Posted : 14/06/2023 9:05 pm
Take the whole thing off, clean with isopropyl alcohol and use 3m vhb tape cut to shape.
Posted : 14/06/2023 9:39 pm
I did a ‘temporary’ fix with Sugru on a downtube protector that was starting to peel off several years ago and it’s still going strong
Posted : 14/06/2023 10:39 pm
What Kramer said.👍
Posted : 15/06/2023 8:29 am
