Has anyone got any experience/knowledge of fitting these brakes to post mount forks? The caliper is IS mount and i'm fitting it to post mount forks, the rotor is 180. I've been told that Hope bracket HBSM20H with a 203 rotor is the only way to fit them but i dont want to go to that size rotor.Any ideas???
I think that is the only way. I have one of those brackets if you want it
Cheers TandemJeremy, may well take you up on that, i'll let you know. How much are you wanting for it?
Same conclusion I came too - 203mm rotor and Hope mount IS to post (+20mm) seems the only way but, on some new Magura forks its a no no as the post mounts are set for 185mm rotors +20mm for the adapter +20mm for the caliper.....
Make sure your forks are a post mount set for 160mm forks, but most are.
Alternatively buy some Pikes or last years Revelations and use the IS mount on them. A bit drastic though for a smaller rotor.
Also get an IS to IS for 160mm to 185mm and put the 185mm rotor on the back. That way the 200mm rotor won't look so massive.
What CHL said. I've recently been round this particular roundabout + came to the same conclusions.
