M15 15mm ID bore wa...
M15 15mm ID bore washer or spacer help?
[#13530624]
Hi, I'm needing a 15mmID spacer for a free hub (chosen) and struggling to find one. Ideally 2mm thick and 2mm deep (OD 18-19mm). Can anyone help or have something suitable knocking around? Thanks Chris
Posted : 14/06/2025 5:18 pm
I’ve got some aluminium sump plug washers kicking around the workshop. They are M15 I’ll measure the outside diameter of them to see if they’ll fit.
Posted : 14/06/2025 5:29 pm
19mm diameter
1.5mm thick
Posted : 14/06/2025 5:44 pm
Ohhh those could be spot on. Thanks for the suggestion. I've found a cheap pack on good old Prime so will try tomorrow. Brilliant. Thanks
Posted : 14/06/2025 5:51 pm
Or search for 'stand off spacers' on eBay. Seller was 'Ultraturn' and did many variations.
I had to do something similar to run a different axle in a front wheel due to an obsolete part.
Posted : 14/06/2025 8:31 pm
Two sump plug washers worked perfectly. Thanks again!
Posted : 15/06/2025 5:48 pm
