Lyrik technical hel...
[Closed] Lyrik technical help please...
[#3425000]
Hello all,
Just wondering if anyone can talk me through a bit of a mod on my lyriks? I've heard that a non u-turn spring will fit in a u-turn fok but I'm not sure exactly how.
Thanks in advance!
Posted : 04/12/2011 3:32 pm
Anyone?
Posted : 04/12/2011 7:38 pm
You'll need one of these: -
to go with the spring.
total cost will be around £70.
A lot of cost for no difference in performance.
Posted : 04/12/2011 7:44 pm
What are you trying to achieve as an end result? Is this so you can get a 170mm fork? If so, there's another way round it that costs about a tenner
Posted : 04/12/2011 7:49 pm
I've got a u turn lyrik with a medium spring and a non u turn firm spring. Just looking to put the two together! Sounds a bit more expensive than I'd hoped though...
Posted : 04/12/2011 8:03 pm
jonedwards - tell me more and does it work with solo air?
Posted : 04/12/2011 8:16 pm
I've got a firm u-turn spring - red - you can have for £25
Posted : 04/12/2011 10:25 pm
indeed JE...what's the 170mm mod? I believe Konastoner has mentioned cutting the u-turn spring on another thread, is it that?
Posted : 04/12/2011 10:37 pm
neilnevill, that mod is to get 170mm on a standard U-Turn on the cheap.
OP - I've had a re-think and it cannot be done with a non u-turn spring, the rebound damper has around 175mm of travel which means that there is 5mm of play due to the spring not being fixed to the shaft unlike a u-turn. There must be something different in the rebound / MC side of the non u-turn models.
You can test this by undoing the u-turn spring at the bottom, pull the lowers and you gain the extra travel.
Posted : 05/12/2011 9:16 pm
Paging Hora....
Posted : 05/12/2011 9:21 pm
