Hi, I’m trying to get my 2017 Lyriks serviced and need a new Charger Bladder for them. Can’t seem to find one anywhere in the UK. Don’t suppose anyone can help? It’s the Lyrik B1 one I need.
Thanks.
If you already phoned the usual places....
Not ideal but Zyrofisher were selling the complete charger 2 for £138. (ebay outlet)
In the vast scheme of things its a new damper for little over the cost of a full service and post.
When you get availability of the bladder you could sell the other charger and recoup most of that.
If it's the same bladder as the A1 Pike I have one you can have for postage. Unused, obvs.
Thanks stevextc will look into that on eBay.
Teethgrinder that would be amazing if it’s the same. Don’t suppose it has a part number at all does it on yours?
Thanks.
It's all I have left from this kit:
Thanks is it 29+ and 2017 ish? If so think it will fit.
It was 2017, 650b.
RockShox Front Internals Right Charger Bladder Assembly Lyrik B1 / Pike 29+
This is the part I need. RSP031020.
Thanks.
No idea if it's the same, sorry. It's yours if you want it. Can post tomorrow am.
Yes please I’ll take it and hope it’s the same worth a try. I’ll message you my email to sort payment. Thanks.
Doesn’t seem to be working. It’s Jonjo hill at icloud dot com.
Thanks.
RSP031020
Is buy to order on ZyroFisher
Is its the assembly you need or just the bladder? WSS do aftermarket bladders.
The lyrik and pike bladder are different lengths. I thought I might be able to do the same but after investigation I found they were slightly different. Lyrik is the longer one. Not sure what the actual measurement diff is however.
I was hunting for a lyrik B1 bladder and you can only get them in full rebuild kits, which are 50 pounds or so. The only place I found just the bladder was in New Zealand!
Thanks seems like a minefield.
Pike A1/2 uses a short straight bladder, Lyrik B1 uses a straight longer bladder, Pike B1 and Lyrik C1 use a hour glass shape bladder, both the same length.
RS dont sell the B1 or C1 Lyrik bladders IIRC or if they do sell the B1 version they ar every hard to get hold of. Drop me a message and I gave sent you a WSS one tomorrow.
