Low stack height st...
[Closed] Low stack height stem's and headsets
[#3683859]
Are there any nice, stiff, AM/FR stems that are smaller than the usual 38-40mm stack hights?
Want to buy some Revelations, but the pair I've got in mind have a 170mm steerer.
My headtube is 108mm
So the options are either a normal headset (25-30mm stack height) which leaves ~30mm for a stem. Or a Crank Brothers Headset (22mm) and a normal ~40mm stem.
I need a new headset anyway, and CB are cheep on CRC so I could always buy 2 to get arround the inevitable returns. And I'd need a new stem as the current easton Vice is huge!
So recomend me a stem and headset with a total stack height less than 62mm.
Posted : 16/02/2012 12:54 pm
Sunline stems are v. low stack, on salt at CRC. Ragley stubbing looks v low also.
Posted : 16/02/2012 12:58 pm
spank spike are about the lowest.
I ended up going the CB headset route on sale at CRC.
Posted : 16/02/2012 1:00 pm
Superstar Zephir is also pretty low stack height.
Posted : 16/02/2012 1:02 pm
+1 on the spank spike.
Posted : 16/02/2012 1:15 pm
I did the spank spike / cb headset thing and managed to use a 155mm steerer set of domains on a 456, was well pleased as the set up saved the forks.
Posted : 16/02/2012 2:04 pm
I've got a similar problem after swapping forks.
Any alternatives to a CB headset, they don't sound very reliable, going by the reviews on CRC ?
I'm currently using a Hope headset without the top cap and O ring, which isn't ideal, but it's gained me about 4mm.
Posted : 16/02/2012 2:21 pm
I've just fitted a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=69395 ]basic loose-ball headset[/url] to my Tazer for exactly the same reasons. Cheap, yes - but they do come with basic dust seals so whack a decent amount of quality grease in there and you're good to go. Stack height is around 22mm and quite a bit cheaper than a Crank Bros.
Posted : 16/02/2012 2:28 pm
Hmmmm, thinking about it I reckon I'll pass up on them as the extra £80+ on headset and stem makes them not so much of a bargain.
Posted : 16/02/2012 2:32 pm
Yes I got the headset for £22 from crc and had the stem already so not too bad .
Posted : 16/02/2012 3:54 pm
Just get a semi integrated HS from Cane Creek - £25 ish for the 10 series cheapo and £50 for the 40 series with twin ACB. Stack heights are 4mm lower + 8mm upper. Still leaves you 50mm which should do just about any stem
Posted : 16/02/2012 4:20 pm
