Long, slack, short-...
[Closed] Long, slack, short-travel steel hardtail ?
I’ve only ridden one briefly and that was an original Ti Spaceframe, but I wonder if this is what a Jeff Jones is made for (despite the lack of suspension fork!)?
Posted : 04/09/2019 10:19 am
I’ve always had a soft spot for Stanton, but coming from a longshot Cotic even the 21” Sherpa is looking pretty short
Yeah they've lengthened them slightly for the Switch9er frames but the Sherpa does feel shorter in comparison (because it is).
Posted : 04/09/2019 11:15 am
Nobody has mentioned Nordest... I've recently swapped from a Cotic SolarisMax to a Britango and absolutely love it.
Posted : 04/09/2019 2:43 pm
Nordest is a good shout, although the Sardinha is probably a better match to the OP's original description for some folk than the Britango would be. Similarly, a Solaris Max is really happiest with 130-140 forks and then a burlier build takes you into very capable trail bike territory.
For my own part, I'm looking for a frame that can be run rigid or 100mm to replace a 2007 Inbred 29er. I looked at the Nordest but dismissed them through cost; a Genesis Tarn falls about halfway between the two but if I can run my existing wheels & some build components on the new Bootzipper, which I can, then that's a better route to go down. The old frame was carbon rigid until fairly recently and hasn't actually killed me for fitting the short bouncy fork. yet... Maybe Brant loves rigid bikes himself, so can explain why I'm banned from trying such a short fork on a Bootzipperk..?
Posted : 04/09/2019 3:30 pm
Maybe Brant loves rigid bikes himself, so can explain why I’m banned from trying such a short fork on a Bootzipperk..?
Crack on.
Issue is that the bootzipper 650 is designed around a 405mm fork length, and the 29in one around a 440mm fork length.
Compare that to (even) a sagged suspension fork and you’ll see why.
Posted : 04/09/2019 3:41 pm
Ah, point taken, thanks for that Brant!
A tape measure is a wonderful tool...
How do you think a Big Dog would be with a 510mm A to C, 100mmm travel fork then?
Posted : 04/09/2019 10:10 pm
Isn't the bottom line there that any hardtail that's going to smash through rubbly chunder like a FlareMAX or similar is also going to need tyres to suit and be burly enough that riding it along back lanes is going to be a chore at best.
If you really want that, get a spare back wheel for your Cotic and stick a Rock Razor or similar on it. It'll roll faster and still smash through stuff.
Or accept that there's more to riding bikes than just pointing them downhill without having to think about lines and get something that'll cope, but be fast elsewhere too like a gravel bike or a cross bike. You'll get fitter, enjoy the easy stuff more and might even up your skill level riding on off-road stuff, though that's arguably a completely different thread.
Posted : 05/09/2019 10:26 am
@willalone Do you have two accounts, or is this just a popular swap?? I've just bought a SolarisMAX frame from someone on here who had bought a Britango
Posted : 05/09/2019 10:34 am
IME some (a lot) of riders go overboard when it comes to tyres and tread patterns. I've gone back to race kings after years on more gnarr tyres and rellished their zippyness and you just learn to live with a bit of sliding and pick lines to suit. Just picked up some fast tracks in the specialized sale.
Even on natural muddy singletrack you end up just sliding into a wheel rut left by the bike before or slight natural berm and finding grip.
Thats basicly my plan for my scandal as ive an old fork with knackered stanchions that will do untill i can accumulate some pennies for a new fork.
Downside is I'd planned to run it 650b+ but the fork wont do that. So it will need some bolt through 29 wheels too. Which starts to make the full build look appealing.
Posted : 05/09/2019 11:31 am
All suspension forks are the same size when bottomed out. So long as you don't run tons of sag I think that would be more than fine on there.
Posted : 05/09/2019 11:47 am
Brant, that's fine, thanks for that again. The fork is for wrist-saver duties only on rooty, lumpy but not very rocky trails on my commute more than anything. On the current Inbred it rarely goes past half travel anyway. Large, Orange Big Dog please.
Posted : 05/09/2019 1:55 pm
No orange.
Posted : 05/09/2019 2:01 pm
Thanks for all the responses. Especially the ones that were vaguely related to the original question 🙂 I've read them all and although I've only responded directly to some comments I found them all helpful.
It would appear that I'm not the only person looking for something that is efficient on road and tame trails yet still inspires confidence on the more technical stuff. Ton's recent thread was heading in a similar direction and Nordest even have a name for it. Downcountry hardtail. No, I can't see that catching on either.
As a few people have noted though, what this often amounts too in practice is putting inappropriate tyres on a long slack bike. In my dreams the tyres make it efficient on road and tame trails and the geometry gives confidence on the more technical stuff. But it could equally well go the other way. The sketchy tyres mean you don't have the confidence on the technical stuff while the geometry means it's still a slog on the road and tame sections. All bikes are a compromise, but I'm not sure if this is one that would actually work.
Posted : 06/09/2019 12:52 pm
I still think what you should do is stick a tough but fast tyre - Rock Razor is a good one - on the back of your FlareMAX and see how it feels on the sort of rides you're talking about. If you find that fast enough for your mixed rides with the current front tyre, then you could run a similar combo on a hardtail no problem. Of course the question then is why you wouldn't just run a fast tyre on a spare wheel on the back of your Cotic and save a bunch of cash, but that's arguably a different thread.
Also, just because there are two people looking for the same solution and some marketing genius has invented a name for it, doesn't make it a real thing - just saying 😉
Anyway, good luck with it. To me it sounds like an excellent excuse to buy yourself a SodaMAX 🙂
edit: sorry, I keep repeating myself like an idiot.
Posted : 06/09/2019 1:27 pm
I still think what you should do is stick a tough but fast tyre – Rock Razor is a good one
Good idea, except that's what I've got on there already 🙂
You could be right though, I may have the perfect bike (for me) already. Most of my riding is "Exploro" though i.e. picking trails I've never ridden before off the OS map and checking them out. When I get back from 30 miles that turned out to be all road, gravel and forest tracks I can't help thinking that the FlareMax might have been overkill 🙂 But when I suddenly find myself faced with a tricky descent I'm really glad I've got it.
Edit: SodaMax is a great call, except I have an irrational hatred of grey bikes. Daft I know, but there you go.
Posted : 06/09/2019 1:40 pm
 StuF
Different set of wheels can make a huge difference. On my Soul, I run either a Vigilante/Riddler (f/r) for quick local bridleways / canals or a pair of 2.6 Bontrager SE4 for the peaks when I want a bit more grip and squidge at the expense of speed on the road. The different tyres transform the Soul, and suits me for 95% of my riding. Hopefully keeps me from succumbing to a Rocket/RocketMAX
Posted : 06/09/2019 2:07 pm
The downside of tubeless, a spare set of tyres now requires a £200 investment in wheels to go with them.
PITA for me right now as i just rebuilt some new lightweight qr 29er wheels to put fast tyres on for the remainder o the suummer and save the cheap oems for winter tyres. Then the new scandal comes allong with boost and bolt through. So im confronted with either rebuilding them again, selling them, changing plans or resigning to another two sets.
Posted : 06/09/2019 2:19 pm
My worthless opinion:
Slack and Long
Pros = great for going down
Cons = makes for pretty boring bike handling everywhere BUT going down. I would go for a little slack and a little long for an all round bike. These super long/ slack bikes today are a bit of a pig to get to do anything except go fast downhill.
Having said that I am about to try a long(ish) slack(ish)frame with 420mm chainstays so I will see if that makes a difference.
Posted : 06/09/2019 2:53 pm
Sounds like you can run a sus fork on the front of the Bootzipper. It'll just have to be 26" front 29" back.
Posted : 06/09/2019 3:06 pm
It would appear that I’m not the only person looking for something that is efficient on road and tame trails yet still inspires confidence on the more technical stuff. Ton’s recent thread was heading in a similar direction and Nordest even have a name for it. Downcountry hardtail. No, I can’t see that catching on either.
No, you are definitely not. Although I would also add the ability to run and rigid fork and nearly fat tyres, so I can ride it in the snow in cold weather.
Posted : 06/09/2019 4:39 pm
Page 2 / 2
