Buying an XT rear mech should I go long or medium cage to go with 22-32-44 chainset and 11-32 cassette?
keppoch
Long cage with triple set up
long
Thanks fellas.
keppoch
[inserts spanner in the works]
always used short cage myself since my first Clockwork in about 1992 and never had a problem. Currently using short cage on the P7 with 11-34 and 22/32/44. Full suss might not work, what with chain growth and such jiggery pokery.
[removes spanner]
Rob
Medium to keep it away from the rocks?
I have a short cage on the bike with a double and bash and a long cage on a 22/34/42 never really notice a real difference.
from mtbr
Manufacturer stated derailleur capacities are as follows:
Shimano long = 45T; medium = 33T
SRAM long = 43T; medium = 37T; short = 30TSpeaking from experience, Shimano is a bit conservative in their capacity rating. I can only assume the same is true of SRAM (I'll get to that, too).
The easy capacity formula is to add your big ring & cog sizes, then subtract your small ring and cog sizes. It looks like this:
cap req'd (T) = (BIG ring - small ring) + (BIG cog - small cog)
...so for a typical 44-32-22 mountain crank & 11-34 cassette...
T = (44T - 22T) + (34T - 11T)
.. = (22T) + (23T)
.. = 45T
