Loctite 271 - Too m...
[Closed] Loctite 271 - Too much??
The red stuff, number 271, is that too much for rotor bolts?
I mean the rotors are gonna need to come off at some point but all being well not in the near future.
Apparently you can get the stuff to loosen up with heat but how much heat?
Merry Christmas btw
Posted : 24/12/2009 5:13 pm
 JRTG
yes! ruined some ti rotor bolts its tough stuff!
Posted : 24/12/2009 5:14 pm
Ok so do I need to clean it out of the threads in hub
Posted : 24/12/2009 5:31 pm
 JRTG
run a high torq rotor bolt in the threads to clear some of it out. a little left will probably be ok.
Posted : 24/12/2009 5:35 pm
Hmmm, I see problems ahead 1) What's a high torge rotor bolt? and 2) Where will I get one at 17:30 on Christmas Eve?
Posted : 24/12/2009 5:37 pm
No Blue loctite? If the threads still have a bit of loctite on them just put the bolts back in, they should be fine
Posted : 24/12/2009 5:47 pm
 JRTG
yep don't worry if the locktite is dry it doesn't really matter. put them in and enjoy!
Posted : 24/12/2009 5:50 pm
Only use the blue stuff, you'll probably get it in halfords or any other motor factors
Posted : 24/12/2009 5:59 pm
Cheap trick as long as the threads are clean a spot of nail varnish will do the same job as blue loctite
Posted : 24/12/2009 9:17 pm
