Liteville 601 owner...
[Closed] Liteville 601 owners - what tune shock?
Had my vivid Air returned under warranty by SRAM but they've sent an ML instead of the MM I sent them stating that it is more tuneable with the frame.
What tune shocks are you guys running?
Posted : 18/08/2016 11:10 am
Pretty sure mine's MM
Vivid air has behaved itself pretty well for me on the XL 601. What failed with yours?
Posted : 18/08/2016 3:18 pm
It was knocking on rebound. Known issue apparently but got a nice new one now.
Spoke to TF and they confirmed that an ML should suit the frame/linkage design better..
Fitted and out for a ride so guess I'll find out
Posted : 18/08/2016 5:50 pm
Standard MM on mine, you could always drop Liteville a message about it.
Posted : 18/08/2016 7:21 pm
Well, 1st ride impressions are really good. Used my base settings from the MM tune (slightly higher air pressure) and made a couple of rebound/compression tweaks on the way round.
Doing a very similar route to compare, the ML was a fair bit quicker (up and down).
I did ask Liteville about an ML tune a while ago, as a Vivid coil I was looking at was that tune, but they never got back to me.
Posted : 19/08/2016 8:53 am
