Lighter road wheels...
[Closed] Lighter road wheels?
I’d say your “experience” was somewhat biased by either your expectation
I would replace "somewhat" with "definitely". If you can honestly feel the difference of a 100 gram lighter hub then I have a load of mattresses with a pea underneath the bottom one that I would like someone to find...
Posted : 14/12/2020 9:28 am
Can't believe this whole thread is going on and on about light v aero and no one has mentioned tyres
Posted : 14/12/2020 10:27 am
The thread is about wheels, I started another one about tyres 🙂
Posted : 14/12/2020 11:06 am
You lot keep slipping back into science and obsessing about proving stuff.
This is the subjective, lighter is betterer thread. If you want to start with yer fancy equations and empirical evidence (gah!), bugger off and start a thread for like minded boffins. 😁
Posted : 14/12/2020 1:17 pm
 jwt
Not getting into the debate about the science, but I bought some scribe 38-50 carbon rim brake wheels, I live in the hilly part of the south lakes and they 'feel' smoother than the two previous sets of aluminium rim wheels, but as mention above it can all be very subjective?
They do look nicer though!
Posted : 14/12/2020 1:36 pm
People keep confusing the two, Miles!
Posted : 14/12/2020 7:11 pm
Life is too short to ride heavy wheels. It's the biggest improvement you can make to many bikes outside of getting fitter yourself.
When you can get a set of 40-50mm aero weapons for ~1550 grams and £800 that's the best of both worlds. Speed on the flat, spin up easy etc.
If you don't believe it then buy a second hand set and if you don't feel a difference v a stock alu low profile rim then sell them on. You won't have lost much!
Posted : 15/12/2020 2:41 pm
When you can get a set of 40-50mm aero weapons for ~1550 grams and £800 that’s the best of both worlds. Speed on the flat, spin up easy etc.
1550g doesn't tell the whole story as I showed above. Hunt Wheels for example have low weights, but the rim weights are often comparatively high when compared to others and Hunt save mass on the overall wheelset by using a low spoke count and lightweight hub, both of which matter far less to the feel of the wheelset.
For example, A Hunt Limitless 48 rim is only 22.5mm wide internally, but 35mm wide externally and weighs 510g A Light Bicycle Falcon Pro 45mm deep rim with a 24.5mm internal width and 31mm external width is ~400g. As such, my wheelset, with comparatively heavy hubs and more spokes is actually slightly lighter.
It's a similar story with the Carbon 50s, but maybe the Aerodynamacist rims are better - there's no rim option, so I can't tell.
Posted : 15/12/2020 3:09 pm
Yes but I'm not comparing similar 50mm wheelsets, I'm comparing v the generally heavy (1.8-2kg), a bit rubbish stock wheels that most normal road bikes come with.
The hunts or your super researched wheels will still feel better/faster/easier than the stock rims which most people upgrade from. Arguably when climbing steep stuff at low speeds the Hunts would be better than your wheels as they are still lighter overall. Let's be honest though is it really that likely to be noticeable?
Yes there is loads of marketing spin, but it's not really any different to any other product category!
Posted : 15/12/2020 3:49 pm
Arguably when climbing steep stuff at low speeds the Hunts would be better than your wheels as they are still lighter overall. Let’s be honest though is it really that likely to be noticeable?
No, the Hunts are still heavier, but only by a tiny fraction, maybe 3-4%, but what I'm saying is that more of my...lightness? is in the rim, where it matters, hence even though on paper mine are only a fraction lighter, becase of where the mass is, they should feel significantly better, like shaving 200-250g (1/2lb) from your rims/tyres.
I suppose what I'm saying is, don't just buy on wheelset weight, try and find out where that weight is in the wheelset. Hunt's carbon spokes will help a little here as they're 25% lighter, but even that is only 20-24g per wheel.
Posted : 15/12/2020 4:20 pm
Is there a better place to go than LB for rims?
Posted : 15/12/2020 9:10 pm
Nextie often have more variety, but are sometimes slightly heavier, but only 5%.
I’ve got both - have a look at the “things I’ve built thread” for a selection of Nextie and Light Bicycle rim wheel builds along with their weights.
Posted : 15/12/2020 9:14 pm
Daffy
I’d say your “experience” was somewhat biased by either your expectation or maybe, possibly the bearings, whereas my “primary school experiments” are at least backed up by science and evidence…
You're making the exact same mistake you already made, again. My expectation was that I wouldn't feel any difference, in fact for a long time I felt exactly as you do- I was surprised that there was an improvement and it took a little while to admit I'd been wrong.
And it was replacing a free-rolling cup-and-cone hub with a brand new cartridge bearing hub so the only difference the bearings would have made, is more friction (though, on an inconsequentially small level of course and not worth mentioning)
But you carry on.
Posted : 15/12/2020 9:54 pm
Science doesn’t lie and the math isn’t wrong, but by all means keep telling yourself that it does and is.
Either there’s another variable that you’re not mentioning, or it’s bollocks.
Posted : 15/12/2020 10:11 pm
Daffy is right, the science doesn't lie. That why it exists, why we don't measure things by feel etc.
Posted : 15/12/2020 10:17 pm
I hate the 'science doesn't lie' line. Science is just a body of evidence. The problems happen when people take that and extrapolate, which we always do. It's the extrapolation that's the tricky part.
Another thing. Whilst it does happen that people spend money on something and want to believe it's better so they perceive improvements that aren't there - it's not guaranteed. Some people are honest enough and perceptive enough to make rational judgements.
Posted : 15/12/2020 11:33 pm
My money is on the modelling not accurately replicating what actually happens on the road.
Posted : 15/12/2020 11:44 pm
Math? WTAF is math? Unless you're a septic, hang yer head in shame... 😕
You lot still arguing about science and evidence? Tsssk. Warrawasteoftimeandeffort... 😁
Posted : 16/12/2020 12:05 am
Molgrips the "science doesn't lie" line is completely appropriate when someone is claiming to have felt a difference that just can't be there.
I thought we had done the whole "your body doesn't measure things well" thing to death, surely?
Do you measure distance by looking and guessing? If your ride feels like harder work does that mean is was slower or do you look at power, speed etc?
Posted : 16/12/2020 12:12 am
We can obviously feel things, even minor changes. If I change a part on my bike and make it 200 grams heavier or 200 grams lighter I can feel the difference when picking up the bike. I wouldn't be able to tell you it is 200 grams different but I would know it was lighter or heavier by a small amount.
My point on this particular example is that while you may feel that the bike is a tiny bit lighter there is no way you could feel whether the hub shell had been reduced by 100 grams, or the axle had been reduced by 100 grams or indeed the steerer tube had been reduce by 100 grams. That is where I would call BS.
Posted : 16/12/2020 8:30 am
A person may feel that 200gm, they may not. But they may think they feel a difference that isn't there. You just can't trust it.
Agreed on your specific example.
Posted : 16/12/2020 8:52 am
Molgrips the “science doesn’t lie” line is completely appropriate when someone is claiming to have felt a difference that just can’t be there.
What difference exactly are we talking about again? The lighter wheels or the hub thing?
I might struggle to explain Northwind's observations on hubs but I'm not going to say that it can't be there. Anyone with a knowledge of science and its history should feel pretty nervous about saying things like that!
I'd put that anecdote on the pile with the other anecdotes and treat it accordingly. That is not to say it's worthless, it's just heavily caveated. Anecdotal evidence is still evidence, of a sort, just don't treat it as if it were higher grade than it is.
Posted : 16/12/2020 10:45 am
WTAF are you talking about @Molgrips ?
This isn’t quantum physics, is ****ing classical mechanics. There is literally no more proven vein of science/math.
Mass at a distance exerts or resists a greater force equal to the square of that distance.
This is Key Stage 2 Science. My 8 year old can do this stuff.
Posted : 16/12/2020 11:24 am
A person may feel that 200gm, they may not. But they may think they feel a difference that isn’t there. You just can’t trust it.
I agree to an extent in that I wouldn't trust someone to feel a 100 gram difference in an 8kg object but there comes a point where you can trust feel.
If you give me a 50 gram object and a 10kg object I will be able to feel which is heavier 100% of the time and I would be happy to put everything I own on getting it right!
Posted : 16/12/2020 11:45 am
This isn’t quantum physics, is **** classical mechanics. There is literally no more proven vein of science/math.
Not that part you prune.
The question is whether or not it makes a palpable difference.
You apparently can't though, you appear to be confusing it with the theory of gravity 😉 And I'm pretty sure it's not KS2 either.
Posted : 16/12/2020 11:55 am
No - I'm not. Classical Mechanics studies objects in motion, this includes the branch of Analytical Dynamics which specifically covers inertia - the very thing we're talking about. I thought you had a degree in Physics...?
I = MR^2
If R is small, I is VERY small unless M is bloody huge. Where R is equal to or greater than the magnitude of M, M can be small and still give a large value for I. Thus rim weight on a bike is literally worth 1000X more than hub weight unless the hub has some monstrous diameter like a Rohloff or a hub motor.
Whilst I don't doubt that NW et al can feel the 1/2lb difference that bike weight (regardless of where its is on the bike), what I do doubt is that you can really feel it when you step on the pedals and accelerate, especially if the bike is not at rest.
Posted : 16/12/2020 1:24 pm
Sorry, I'm not gonna listen to a bloke that can't spell 'maths' - twice 😝
Posted : 16/12/2020 1:50 pm
Page 3 / 3
