Advice on pedal fit...
[Closed] Advice on pedal fitting
[#11527876]
Hi all,
I've just purchased a set of DMR V8 pedals to install on Shimano Deore crank arms. It's look like the crank arms have a recess for a washer. In the instructions that came with the pedal it says to fit the pedals flush, if the arms have a recess then a washer must be fitted. I don't have any washers, is this necessary and if so can someone point me in the right direction for them for my crank arms.
Thanks
Posted : 10/12/2020 7:36 pm
I’ve never had or used pedal washers on any Shimano cranks before, only on SRAM.
SRAM cranks come with them.
Posted : 10/12/2020 7:52 pm
There's no flange on the spindle and if there's a sharp edge on the spanner flat it can gouge into the crank - take a file to the edge of the spindle to minimise the risk of damage.
Posted : 10/12/2020 8:07 pm
Are you sure the spindle doesn't fit in the recess? Dumb, slightly insulting question I know. What's the model ref for the cranks?
Posted : 10/12/2020 9:18 pm
Hello, thanks for replying - from the Nukeproof site it's Shimano M5100 Deore 10 Speed Crank. I'll attach a couple of pictures.
Bike pic 1
Bike Pic 2
Bike Pic 3
Posted : 10/12/2020 10:36 pm
Dovebiker has it, the spanner flats on V8 pedals are exposed, and will gouge the crank arm. Trying to file edges off hardened steel will be a tough job, visit your LBS and get some washers (or e-mail me your adress, and i'll post you some).
Posted : 11/12/2020 7:07 am
Posted : 11/12/2020 7:33 am
I've always used washers and Copper slip on the threads .
Always use washers, not because any manufacturer tells me to, but because it's good engineering practice, and a bit of anti-seize on threads.
Posted : 11/12/2020 9:46 am
 goby
Anti seize for sure! Forgot on one of my pedals and OMG was a pig to get out!
Posted : 11/12/2020 10:00 am
