Anticipating the arrival of a dropper post, I'm thinking how I might route the cable along the top tube. The existing cable bosses are already taken up with brake and gear cables, and I know I could just zip-tie it on, but there must be a more elegant solution.
Give me some inspiration...
Drill a couple of holes and go internal. Snot like your riding is going to push the strength envelope of the frame now is it.
I just ziptied to the brake hose. Looks fine.
Remove your front mech and use the guides for your dropper 8)
Send the dropper post back-if unopened you should get a full refund
Er, okay 😕
This is mine, it would probably work better with smaller zip ties.
[url= http://farm9.staticflickr.com/8488/8271412559_e2becceccb_z.jp g" target="_blank">http://farm9.staticflickr.com/8488/8271412559_e2becceccb_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/29930426@N04/8271412559/ ]P1010442[/url] by [url= http://www.flickr.com/people/29930426@N04/ ]i_ache[/url], on Flickr
[url= http://farm9.staticflickr.com/8343/8271411341_d0f4cecef0_z.jp g" target="_blank">http://farm9.staticflickr.com/8343/8271411341_d0f4cecef0_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/29930426@N04/8271411341/ ]P1010441[/url] by [url= http://www.flickr.com/people/29930426@N04/ ]i_ache[/url], on Flickr
Did you see the bit where I asked for 'elegant' solutions? 😉
Fair point but it works really well. It would be more elegant if smaller zip ties were used.
Ooh, Greeble, I like the top ones 🙂
you can get them here
in funky colours
http://www.sjscycles.co.uk/dia-compe-cable-clamp-prod27772/
zip-tie plus a washer to make a loop for the cable, if that makes sense? I'll try and find a pic...
A guy I ride with has an Ibis Mojo carbon fitted with the new "Stealth" Reverb dropper post, where the cable is designed to run up inside compatible frames.
He has taken the headtube badge off, enlarged the hole that it was fixed to slightly and runs the cable down through the inside of the frame, even though there is no provision for it.
Seems dodgy as hell to me but it's his bike and he did work for a carbon/composites/materials company, so he probably knows best.
Some useful clips and things here:
[url= http://meyle-mueller.onlinekat.de/index.php?customer=rose&lang=en_GB&catName=hk_13#/?onlinekatpage=306 ]http://meyle-mueller.onlinekat.de/index.php?customer=rose&lang=en_GB&catName=hk_13#/?onlinekatpage=306[/url]
