oh well, just me then 😛
This is my wife's initial response to your pic, velomanic
"GET IT OFF THE DINNING TABLE!!!"
Yay 🙂 what chainset on that one ?
My 2009/2010
[url= http://farm6.staticflickr.com/5070/5598068162_0923a461fd.jp g" target="_blank">http://farm6.staticflickr.com/5070/5598068162_0923a461fd.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/bikesnthat/5598068162/ ]Bike stuff for sale 002[/url] by [url= http://www.flickr.com/people/bikesnthat/ ]redmancunian69[/url], on Flickr
Nice bike but overkill for a short commute so sold it last year for a much cheaper alternative.
Bregante what you running now?
2nd hand Spesh Singlecross. The CdF funds went into a Cotic Solaris (by way of a Karate Monkey en route).
The Singlecross is more than adequate for its purpose (and a damn sight lighter)
Apologies for any offence caused to Mrs y0eddy!
The chainset's Ultegra 6700 38/52, a recent addition to see if my legs would handle it!
A biggish gear....
Aye, it's big for the Isle of Man, not many flat roads here!
Hah, I'm on a 34\30 and ran out on some steep stuff up behind lochgoilhead !
Sounds brutal! How are you getting on with the bike?
Yeah, was a bit steep ! Loving it really. It replaced an 07 Jake the Snake, so a lot more comfort, a couple more gears and an extra few pounds. It is more able off road though. Been playing with tyres, between the ones it came with, small block 8's and some other knobbly contis on way. Also have 32c slicks for road duties. No negatives so far, although have kicked the rear brake with left heel a few times.
Loving mine too. I wanted a disk-braked road bike that was both comfortable and able to withstand being ridden hard on poor / broken road surfaces and it does the job brilliantly. Had 28mm Conti GP4S for the summer, just put a pair of GatorSkins on for winter duties. I've made a few changes including swapping the brakes for TRP Hy/Rd's which work really well. Interesting that you've had a couple of heel strikes now they've moved the rear brake inboard. The only change I'd make is to route the rear brake cable down the centre of the top tube for a neater line!
Looks good Jamie 🙂 (wtf is that cage tho ?!)
Ouch 🙁
http://www.zefal.com/en/bottle-cages/50-spring.html
Going for a 2-tone effect.
...which is slightly ruined by the Genesis paint being paper thin and already being down to the bare metal at some points inside the stays.
To their credit, they did send me some touch up paint.
Yeh ouch, still off work from beginning of december
Jamie - mine came with touch up paint, odd but nice touch 🙂
Fine looking bike David 🙂 equilibrium disc would be on my list if looking for something more roadesq.
😀 Not entirely convinced tbh....
The Equilibrium Disc looks like it'd cover what alot of people use their CDF's for (road/rough road/fire road), but better! Although perhaps not quite as good for real off road stuff...
CaptainFlashheart - Member
Not mine obviously, but having seen one of these in the LBS on Saturday, I am feeling a strong lure towards it!
Lovely looking frame, seems strange they spec it as a full bike with fairly average bits. I'd have thought most people would do a custom build on one of them.
CFH - looks lovely but a lot extra over standard one, with as mentioned above not top spec kit. Also brake caliper unmoved on that version, which may or may not be good.
Yep, some of the bits are a bit low end, but a lovely frame.
And, I suspect that people would want to tweak the spec anyway (Commuter, tourer, race bike etc) so better to pour money in to the frame.
They're ok.
Consider yourself convinced.
A lot of money for the full bike, though.
It's got blue brake cables and mudguards. I think "just ok" is about right.
I sold my CdF because I [i]thought[/i] I needed a FS MTB more......... *tuts, shakes head* 😳
ROSE XEON DX-2000 2014 - This looks good for a full build road disc as does the PX Kaffenback 2 (but its quite heavy)
The Equilbrium Disc and Croix De Fer look good but quite steep £££ as pointed out
Haven't found much else that is more roadish [with discs] than CX
First short ride on mine today. It's only taken me 6 moths to put together! 🙄 better pics tomorrow!
[url= http://farm6.staticflickr.com/5490/11547936364_5587cd42ee_b.jp g" target="_blank">http://farm6.staticflickr.com/5490/11547936364_5587cd42ee_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/23986078@N05/11547936364/ ]Fwd: Hmmm lovely day for it[/url] by [url= http://www.flickr.com/people/23986078@N05/ ]carlos_fandango[/url], on Flickr
Nice long steerer Andy 🙂
Just in from first ride since a bit mtb crash 2 weeks ago, 25 quiet road miles on the CDF, Lovely 🙂
First short ride on mine today. It's only taken me 6 moths to put together! better pics tomorrow!
I thought I was bad at 2 months...
CDF on my short, short list for new bike - has anyone put a 29'er wheel set on theirs yet? Does the hub fit across the rear, and what's the clearance like for say a 40mm 29'er tyre (ie 1.6 RR's or similar)?
Lucien, not sure on hub widths as hubs road sized. A 40 mm tyre would go in back. Front standard tyre is a 35mm conti CX, which is pretty close to fork crown
Thanks Iain's, Road hubs are 130mm, MTB hubs are 135mm - would the frame flex enough for these
Lucien, probably, being steel !
The Croix De Fer is spaced for a 135mm rear hub.
Here is the tyre clearance on the lower stays running a 700cc 35mm Schwalbe Smart Sam on a [url= http://www.kinesisbikes.co.uk/products/wheels/crosslight-cxdisc ]Kinesis CXDisc wheel.[/url]
Personally, I wouldn't bother with 29er wheels on a Croix De Fer.
Jamie, glad you popped along 😳
75 Kms today. Out to the Mull of Galloway, Port Logan, Port Patrick and back to Drummore. Feeling a bit tired! V pleased so far. Trundles along quite nicely and easily copes with rough roads
Another pic:
And that's on a 60cm frame with a an inline seatpost and 70mm stem. Looked for other alternatives with shorter top tube and there weren't. Maybe something custom next year if the format works.
That its taken 6 months clearly demonstrated how urgently it was needed 😉
Aye, saddle looks quite far forward too, lovely looking bike tho'. What size are those travel contacts ?
