Lend of ratchet rem...
[Closed] Lend of ratchet removal tool please
[#7743046]
Hello, a bit of a long shot but does anyone based in London or Surrey UK have a DT Swiss compatible ratchet removal tool that they might be able to lend me please? Long story but I have some old wheels and have discovered why the bearings are rumbling. Problem is that I need to remove the ratchet ring to access the offending bearing. As the tool is £60 I thought I'd see if a STW member might have a unit. Thank you in advance for any offers, would also appreciate any advice on how to complete the removal as I understand it can be tricky and I dint want to damage the hub ir spokes. Tim
Posted : 02/04/2016 7:25 am
 br
With specialist tools I've found that you normally need to bite the bullet and buy one, or pay an LBS to do it.
Posted : 02/04/2016 8:43 am
Beyond Mountain Bikes in Cranleigh have one (I had to buy it because I broke their last one on a particularly stubborn wheel 😳 ) - unlikely to be free, but if you go in waving a stripped wheel it shouldn't take long/cost much.
Posted : 02/04/2016 8:46 am
 jimw
+1 for getting someone who has the tool to do it for you. I have done a couple and if the hub has had a lot of use it is a real PITA and I have decided to go to my LBS next time. Not that they need doing all that often to be fair.
Posted : 02/04/2016 9:09 am
Heat gun FTW if it's stuck - that's how I released my one which broke the tool first time.
Posted : 02/04/2016 9:15 am
