Left hand shifter s...
[Closed] Left hand shifter suddenly not shifting into big ring
[#1676290]
Half way through ride today my left hand shifter suddenly decided it wouldn't shift from middle to big ring - no crash etc to knock it out.
Have played with limit screws as front mech not moving far enough but hasn't made a difference. Is the shifter broken?
Posted : 05/06/2010 9:49 pm
check somehing isnt jamming the mech like a smll stone or something, if not undo the cable and see if the mech will move by hand, if i do's then its probably the shifter
Posted : 05/06/2010 9:54 pm
 Rio
Could be lots of things. Check your cranks. I had the same symptom last week; a few miles later my left crank fell off. 😕
Posted : 05/06/2010 9:57 pm
SRAM X9?? if so it's a known warranty issue...
Posted : 05/06/2010 10:23 pm
i use sramx9 m8 and ive had my front mech for a while now, i used to have a bash ring on but now have a big ring, mine dosent shift into it unless im in a high gear, i dont know if this is how its supposed to be as its a long time since i used a big ring, or like you say, try messing with the limit screws or buy a new mech if you have tried everything else.
Posted : 06/06/2010 9:09 am
Cable stretched or slipped a little.
Posted : 06/06/2010 10:01 am
can you push the mech by hand into the correct position?
Posted : 06/06/2010 10:08 am
is it a plastic bodied shifter?? I found that the plastic had cracked on mine once and it was flexing the shifter therefore not pulling fully to get it on the big ring...
also, give it a reet good clean and gt85 ?
Posted : 06/06/2010 10:26 am
could be caused by many things...but almost certainly not limit screws
Posted : 06/06/2010 10:33 am
 SOAP
+1 for a small stone or crud in the mech.
Posted : 06/06/2010 10:35 am
