Leaky Master Cylind...
[Closed] Leaky Master Cylinder SLX M675
[#4577181]
Went to bleed my front brake after shortening the hose and as i'm pushing the fluid up from the caliper can see fluid pissing out through the MC diaphram. Anyone else had this issue?
Problem is i got the bikes from Rose in Germany aaaaaaarrrrrggggghhhhhhh!!!!
Gutted as last part of my new 29er build.
Whats your experiences with returns to Rosebikes?
Posted : 20/11/2012 9:59 pm
We've heard of this a couple of times from customers who've used our bleed kits. I'm not sure of the fix to be honest but have you tried tightening the reservoir allen bolts?
Apart from that try and remove the reservoir cover to see if the rubber diaphragm is seated correctly? Could be an assembly issue?
Posted : 21/11/2012 12:24 pm
I had the same problem with mine ,lbs said there is a air release /vent in master cylinder ,i have continued to use with no problems
Posted : 21/11/2012 12:30 pm
Epic - was using one of your kits at the time. Nowt to do with that though i might add 🙂
Peasant - heard that too and like you carried on using it without and adverse affects so seemingly now all fine. Cheers
Posted : 26/11/2012 10:04 pm
