Leaky Avid Elixirs ...
[Closed] Leaky Avid Elixirs - advice?
[#3083988]
Got some elixir 5's recently, and despite bleeding they seem to be taking on air and it seems there's a wee bit of DOT fluid leaking from the compression nut bit in the lever.
When chopping/installing the hoses I pushed them in quite hard as advised and did the nut up as tight as I could with a wee spanner, but I guess I did this wrong somehow.
Just wondering if anyone has any good hints & tips of things to look out for before when i go to fix them, and also any techniques to make sure the hoses are definitely properly in?
Oh and there's a shiny new donkey for the first poster to advise I get some hopes or shimanos instead.
Posted : 25/08/2011 7:00 pm
Make sure the olive doesn't sit too far down when you seat it in the lever otherwise you'll get the leak
Posted : 25/08/2011 7:13 pm
As in too far away from the barb? It looks like it's more or less snug with the barb on the end of the hose, +/- a mm or so.
Posted : 25/08/2011 7:20 pm
Mine did the exact same thing. I took it apart again and the olive didn't look compressed, so reseated everything and held the brake hose in all the time i was tightening the compression nut as firm as possible, so far no leak has returned.
Posted : 25/08/2011 7:31 pm
