Picked up my newly built Canyon Ultimate AL this morning 😀 from the LBS who built it up for me (already had wheels and bars).
Rode it around the corner and noticed they'd replaced my old skewer with a new one. No problem you might think, but that is the skewer for my turbo trainer. So, i popped back and asked if they still had it. A rummage in the skewers draw and it isn't there - 'I think the old one was replaced because it looked a bit ******. We'll have a look and ring you later.' Fine my me, easy mistake to make if you've not seen one before.
The bike rides like a dream, handles better than my old Kaffenback, accelerates brilliantly etc. I'm enjoying the ride to work. But then i hit a bump and 'bang!' - oh, dammit, pinch puncture... But hang on, the tyre is still inflated. Then i noticed the bars had rotated in the stem because the bolts were tight enough!
The bars are carbon and there are a couple of scratches (need a proper look later). I'll be popping back to the shop later/tomorrow. What approach should i take? Bombers and make a scene? Demand my money back for the labour? Quietly suggest they check the bars for me?
ime you can torque bars/stems up to the manufacturers recommended setting and still get movement. Scratches are likely to be a) where the clamp is so not seen when refitted and b) cosmetic?
Were bars attached to stem when you delivered bits to them?
They should get you a new skewer for your turbo & go all over the bike torquing the bolts tight.
They should also give you a voucher or similar i think, in compensation for the aggro - £25 maybe? (a couple of hours of your time)
What was the bang?
Speak to them nicely and point out that the consequences could have been MUCH worse than a scrape. Nice talking rather than shouting tends to get better results IMO.
If it had been me I'd have checked all critcal bolts first, but im fussy like that.
wwaswas - Member
ime you can torque bars/stems up to the manufacturers recommended setting and still get movement. Scratches are likely to be a) where the clamp is so not seen when refitted and b) cosmetic?Were bars attached to stem when you delivered bits to them?
Hopefully just cosmetic, not bothered if it is just that. The bars were attached, but the stem was looser than when i check the bolts after the twist (i think)... i still expect them to check everything, though.
wrecker - Member
What was the bang?
Presumably the bars twisting in the stem.
Fair enough. Was hoping for something more exciting.
I'd be quite firm with them. That could have resulted in a nasty accident. I'd certainly expect recompense.
Tricky one, if they charged you for the replacement skewer they should def pay up for a turbo one. If it was gratis then although I guess they should still pay up I probably wouldn't expect them to given they were just trying to do you a favour.
As for the bars/stem - how loose are the bolts? Might be worth trying to torque them up to 4 or 5Nm, if they can still be tightened then I'd have words with them about not doing them up properly. If they're already at 5Nm then as someone above posted, it is possible for bars to move after a decent impact when torqued to manufacturer recommended settings (I'd have hoped they'd used carbon paste though if they're a decent shop).
if the bars are loose then they haven't done the PDI check properly. this is pretty serious procedural error if they are qualified mechanics.
I'd be asking what you actually paid for?
As in life generally, if you go in and act like a twunt you'll get less than if you are reasonable but firm.
thomthumb - Member
if the bars are loose then they haven't done the PDI check properly. this is pretty serious procedural error if they are qualified mechanics.I'd be asking what you actually paid for?
A few parts (BB, front brake, bar tape - rest of groupset was from elsewhere/collected over time) + £40 of labour.
I'll mention it when/if they ring me, and go in all friendly like.
As others have said, at least you're OK
Take away from it the lesson that if you want something doing properly, you're far better doing it yourself than trust someone who tells you they know what they're doing.
sorry i'm not sure i'm following (i am slow ;))
did they build the bike from a pile of parts (some yours, some new) and you left the shop with a complete rideable bike, if you did they should have given it a pdi imo.
How big was the bump? If you were thinking it could be a pinch flat (on a road bike) then it was probably quite a big hit? If so, then not really surprising that something might move, even if tightened properly.
bencooper - Member
I assumed it was a pinch based on the noise, not the force i hit the bump (i've ridden over it many times on my commute).
thomthumb - Membersorry i'm not sure i'm following (i am slow ;))
Yes, pile of parts given (minus the ones listed i didn't have) and left with a completed bike.
What does PDI stand for?
Pre Delivery Inspection
Ah okay - yeah, have a word with the shop, even the best mechanics can occasionally forget things.
i can sympathise with the stem issue
stem will have one torque value and sometimes the bars will state a max torque for the stem. which may or may not be in the same ballpark as the stem.
i know which i use but which do you use.....
defo be calm and nice....its nice to be nice 😉
Do people not just nip bolts up any more?
One mans "nip" is another mans gotta flog it up tight 🙄 Come across that on a daily basis and have had many a discussion with colleagues 🙄
The spanners I use most on a daily basis are 22mm, 27mm and 32mm. Lots of old imperial on most of the 40yr old machinery
Carbon paste on the bars/stem I take it??
Aye, but on bikes the more delicate components tend to have bolt heads that round before you get to silly tight.
Aren't Canyon an online retailer?
Did you buy your bike online and ask LBS to put it together for you with some of your existing kit?
mega - Member
Bought frame online + some bits i already had + bits bought elsewhere + LBS assembly
