larger SLX / XT sin...
[Closed] larger SLX / XT single chainring?
[#9822824]
if Shimano don't do anything bigger than a 34(?) is anyone using anything larger from anywhere else?
if I've understood it correctly it'll need to be 96mm BCD Asymmetric with 7mm bolts (different to XTR @ 8mm?)
Posted : 07/02/2018 2:17 pm
thanks; still a bit grumpy with them after I ordered what I thought was the one I needed and then they wouldn't accept return outside of 15 (or however many) days as I didn't try to fit it until afterwards.
I'll give them another go if only / best option
Posted : 07/02/2018 3:19 pm
At the risk of stating the obvious, make sure you've got chainstay clearance for a ring that large.
Posted : 07/02/2018 3:26 pm
good point; new cranks going on later, will check before I click!
Posted : 07/02/2018 4:50 pm
+1 on the check before buying. I now have an xtr 36t spare for this reason as the bike only took a 34 (officially 32!!).
that said, I believe the Shimano chainrings are the same for XT and XTR. The bolt only keeps it against the crank arm, the spider/nuts is what touches the holes and the bolts come with the crankset anyway so must be correct in terms of diameter. The thickness of the ring is identical so length of bolt won't matter. The 34/36 come with spacers (washers to you and I) but the standard bolts fit fine for these and the 32t.
si.shimano.com doesn't seem to confirm any of this so please don't take my word for it as I have no proof. If you're near Reading I can offer a test of a 36t XTR ring though...
Posted : 07/02/2018 10:46 pm
Gamut do a 36T ring to suit M8000 cranks.
Posted : 08/02/2018 10:16 am
