Lapierre Spicy 516 ...
[Closed] Lapierre Spicy 516 question
[#5106692]
The 2013 Spicy comes with fox 34's, does anyone know if you can fit Fox 36 on it?
Posted : 27/04/2013 3:46 am
Everyone has to start somewhere ...you can fit pretty much any fork to any bike but certain basic things constrain whether it 'works'
Firstly does the steerer match the headtube? If your headtube is tapered then you'll need forks with a tapered steerer - you can also get a reducer if the headtube is too large (but obviously not the other way round)
Secondly is the steerer long enough for your headtube and stem?
Thirdly is there a difference in travel between the new and old forks that could invalidate warranties or play with the geometry of your bike
Fourthly will your wheel still fit - 26 v 650b v 29
Fifthly is the fork qr, 15mm or 20mm - and what is your hub?
Finally what colour are the forks
I deliberately left out reference to brakes but obviously you may need to understand if the forks are IS mount or post mount as you may need a new adapter - and watch out for damage to the fork stanchions especially if its an air spring
These will all make more of a difference than an extra 2mm in the diameter of the stanchion
Posted : 27/04/2013 7:05 am
yes you can
Posted : 27/04/2013 1:56 pm
