Lace my owl wheels....
[Closed] Lace my owl wheels....will I die? No really?
Carbon rims competition spokes on 50mm Chinese carbon rims onto Hopes.
Triple laced? Never built a carbon wheel before.
I am going to die, I can feel it....
Posted : 27/12/2016 7:47 pm
 jruk
Depends on the type of owl. Barns are fine. Screech owls? Mental and will kill you.
Posted : 27/12/2016 7:50 pm
If you are just lacing then you can't do any harm. Sheldon Brown has a guide which helped me.
Posted : 27/12/2016 7:54 pm
I reckon you'll only need toowooo cross if these are road rims
Posted : 27/12/2016 7:56 pm
Oh bugger, slight typo. Not road wheels 29+ wheels. 148 boost and 150mm front.
Posted : 27/12/2016 7:57 pm
Try using the Tea Towl. Much better for wheels
Posted : 27/12/2016 7:59 pm
Scardeypants, too funny
This thread is a hoot!
Posted : 27/12/2016 8:00 pm
Sounds like building them will be strixy.
Posted : 27/12/2016 8:15 pm
Ooh, that's good, Wally! Very good!
Posted : 27/12/2016 8:16 pm
This is snowy joke people.
If you can straighten a bent wheel, you can probably build a wheel from scratch. The first half, the lacing, is just about following instructions really. The second half, the tensioning and truing, is more involved and has more potential to go wrong but it's not actually all that hard, especially with new rims and good quality parts.
Realistically the worst that can happen is you screw it up and end up getting a shop to un**** it for you. Which is no worse than just getting them to do it in teh first place. You have to really [i]seriously [/i]screw up to damage a spoke or rim.
If you were just thinking of lacing but not tensioning, some shops aren't delighted to have a pre-laced rim brought to them just for tensioning. Others don't mind. I'd check first.
Posted : 27/12/2016 8:19 pm
I would say make sure that you do your research (Sheldon mentioned above is very good) and be meticulous... you don't want to end up being scraped up off the road by the scops..
Posted : 27/12/2016 8:22 pm
If you've built wheels before, you know the drill however if you can borrow a tension-meter it'll help as carbon rims don't like over-tightened spokes. 3-cross is the norm and no need for anything fancy. Used some Sapim nipple washers on a recent build, helps on rear drive-side to spread the load better.
Posted : 27/12/2016 8:23 pm
Just don't have a barn y with anyone when it goes wrong.
Posted : 27/12/2016 8:26 pm
Not to mention of you get it wrong you'll feel like a twit-too.
Posted : 27/12/2016 8:32 pm
 rs
look fine to me, i'd leave them as is...
but if you must you do know you can just buy a whole true owl, no adjustments required.
Posted : 27/12/2016 8:40 pm
Once youv'e tensioned them, you need to twang the spokes I listen for the tone of each one with your Long Ears.
Also, a spoke condition observation & placement system (SCOPS) is an adavantage if you have access to it.
Posted : 27/12/2016 8:42 pm
I'd be tawn between doing it myself or taking it to a shop.
Posted : 27/12/2016 8:43 pm
Flipping predictive text does my head in.
Posted : 27/12/2016 8:58 pm
This thread could make your head spin!
Posted : 27/12/2016 8:59 pm
