Would you believe while googling an old hub I want to re use I happened across [url= http://singletrackworld.com/forum/topic/help-needed-anyone-know-what-hub-this-is-need-20mm-to-15mm-reducer ]This closed STW thread[/url] from three years ago, where the OP is asking about the exact same hub I have.
The trouble is although there's plenty of suggestions I can't tell if an actual solution was found.
So does Anyone know is a set of adaptors exist that would fit?
it must be an old Novatech/Formula or similar off the shelf OEM hub...
Posted : 23/06/2017 9:44 am
Monday bump...
Posted : 26/06/2017 12:06 pm
