Knocking cassette
[Closed] Knocking cassette
Hope pro 2 with an XTR cassette fitted. New wheel, old cassette. It has developed a load of sideways play between the higher and lower cogs. In fact its knocking and clanging like hell over rough ground. Has anyone fitted shims between the mating surfaces?
Posted : 26/10/2009 7:19 pm
afair an xtr cassette needs a spacer behind it like a Dura Ace cassette does
Posted : 26/10/2009 8:14 pm
Spacer? Does this go on the inside or are you meaning the shim on the locking nut?
When I say play I mean in the direction of the chain travel. The main body has a spider and the smaller gears are loose. Its the spider part that's rocking front to rear.
Posted : 26/10/2009 8:23 pm
When you tighten up the lockring there should be no movement on the cassette / sprockets in relation the the freehub.
Halfbee may have the answer....
Posted : 26/10/2009 8:27 pm
Posted : 26/10/2009 8:30 pm
Other possible is that the lockring isn't done up tight enough - but surely that's too obvious?
Posted : 26/10/2009 8:34 pm
The lockring is taking out the top to bottom play but it is not clamping the gears together. I will google halfbee's spacer idea or try another shim.
Posted : 26/10/2009 8:35 pm
Cheers for pic, halfbee.
Lockring is torqued up to correct setting.
Posted : 26/10/2009 8:38 pm
I guess your lock ring is bottoming out without locking the cassette together proerly
Posted : 26/10/2009 8:43 pm
Yes that seems to be the problem with my new wheel-set. All was ok with the old wheel.
Posted : 26/10/2009 8:49 pm
