Knee Pads, Riding T...
[Closed] Knee Pads, Riding Trousers and Rubbing
So i have two pairs of knee pads, some lightweight 7iDP's and some more substantial Fox ones.
On a recent ride my lightweight pads rubbed the living shite out of my knees, leaving them red and rather tender. we were riding for 4 hours-ish, so a fair amount of time, with plenty of climbing/peddaling.
I have had these pads for quite a while and not experienced this before. A buddy suggested it was due to the trousers rubbing on them and subsequently the pads rubbing on me. Wearing trousers over them means its much harder to give them a readjustment, as i would if i was wearing shorts.
I dont have any intentions of getting rid of the pads, as that seems wasteful and as said it only happens with trousers (well.... thus far, only with my new fox trousers. previous ones have been fine).
So is there an easy solution to avoid this in future? The already mentioned buddy uses chamois cream to help his knees. But i would rather have something more permanent. a tubigrip or similar on before the pad? but that doesnt effect the pads ability to stay in place.
I am keen to hear any solutions that you have found.
cheers!
Posted : 19/01/2022 10:43 am
I wear 3/4 lycras and put the top of the pads under the hem of them.
I then wear mtb shorts or troos on top.
No slippage
Years ago I used to use these knee sleeves from 661 that basically gripped your leg and helped stop the pad slipping. Not sure if such a thing exists now.
Posted : 19/01/2022 10:46 am
It's not the trews.
Put chamois cream on your knees - that will probably solve it.
If not, you've got some frayed or pokey-out bits that are irritating your skin.
Posted : 19/01/2022 10:52 am
Lycra knee warmers under?
Posted : 19/01/2022 11:00 am
@chakaping - my only thought it on being the trousers is they are new and i havent experienced this before. I will try chamois cream in future. And defo investigate if there is anything that could be adding to the rub. It was consistent across both knees.
@kayak23 - good stuff. slippage is what i want to avoid, but sounds like you didnt get any, so another avenue to look at.
@thebrick - good shout! might be worth a punt.
Posted : 19/01/2022 11:19 am
Ok there could be something peculiar with the trews if they are tight round the knees or something, but get that chamois cream on in the first instance.
I started doing it to address chafing and it's been a game changer, several pals have tried it on my advice and had good results.
Posted : 19/01/2022 11:22 am
Not sure about you, but any additional material under my trousers and I'd cook. With the knee warmers its also worth considering that (same with tubi grips) they can start bunching up behind the knee, so might cause other issues
Posted : 19/01/2022 11:23 am
No slippage
This - I used to get bother with pads slipping etc until I worked out how to pull them up and the pull the grippy seam of my bib shorts over the top of them - its a bit 'stockings and suspenders' but it does work!
Posted : 19/01/2022 11:29 am
