Hi Guys,
Just had my wheels fully serviced, new bearings etc...
However, once i mount the wheel in my Klein Attitude frame and tighten the skewer the freewheel locks up, effectively turning the bike into a fixed wheel. Someone at the shop mentioned that it may be something to do with the axle being too short, and that someone must have gone at it with a hammer, however i'm pretty sure there is no evidence of this...
Anyone got any ideas..?
I tried a 2mm spacer between axle and frame, but still no improvement.
It's an XTR 9 speed casssette, dt swiss skewer by the way
IIRC There's a spacer in a 240, behind the drive ring, which can get mangled and not sit right, it'll feel fine until you refit the wheel. I'd disassemble and double check everything.
Thanks for that,
I'll have a word with the mechanic, however is sounds like you probably know what you are doing better than him!!!
