kinesis pro6 disc f...
[Closed] kinesis pro6 disc fork mudguard fitting
[#6588218]
have a pro6 and just about to fit a front mudguard. there is no hole at the top of the fork on the back to pit a bolt into, there is a clear circle but it is covered over. Is this just paint that has covered the hole and therefore just break the seal with a bolt and screw it in?
thanks
Posted : 27/10/2014 8:40 pm
I've fitted my full guards to the same place, mine was clean and visible though when I first went to fit them. Threads by dropout weren't great and had to be chased out.
Maybe an exploratory pokey object?
Posted : 27/10/2014 8:48 pm
Same as lummox in my case.
It must be painted over, see if you can get trough with a needle.
Did you managed to fit the guards at the back?
Posted : 27/10/2014 9:10 pm
poked a pen through, no fitted a rack on the rear then fitted an old plastic guard to the rack as that is easier to take on and off for the commute than both a rack an guard.
Posted : 27/10/2014 9:54 pm
used to have full mudguards but its spring and dusty in Aus'
3yrs oldish kinesis forks that came as standard
[URL= http://i432.photobucket.com/albums/qq47/robertedj/20141028_164617_zps91fa226d.jp g" target="_blank">http://i432.photobucket.com/albums/qq47/robertedj/20141028_164617_zps91fa226d.jp g"/> [/IMG][/URL]
Posted : 28/10/2014 7:45 am
